![]() | Home > In Car Electronics > Switches Harness and Clock in TDCI |
carrotbay Member Since: 18 Aug 2013 Location: Northants, UK Posts: 702 ![]() ![]() ![]() |
Hi .. I’ve just done this job today.
There’s no need to extend any of the cables. This is what I did to get it to fit. For the wiring harness for some of the switches I took off the fabric insulation, separated the cables for the switches on the left side and re-wrapped them in fabric harness tape. Did the same for the rest. You then have separated cables that can go down the left of the head unit and across the top. They then reach the new panel (inc hazard light switch) on the right. I still couldn’t get it to fit until I finally took off the metal bracket at the back that runs from the tubular cross bar up to air vents. It’s attached by 5 plastic screw fixings. I then just made sure all the ISO connectors etc were on the right of the head unit out of the way and not behind the unit getting in the way. It’s still a tight squeeze but fitted. 2008 Defender 110 XS SW - M57N2 / 6HP28X |
Michaelkan Member Since: 19 Dec 2018 Location: Bath Posts: 149 ![]() ![]() ![]() |
Ok will give it another go at it.
But did u cut the bottom of the clock? Thanks. |
Hi .. no, I didn’t need to. The clock sits on the top of the head unit and it still fits although it’s tight. 2008 Defender 110 XS SW - M57N2 / 6HP28X
Is your fascia a two piece or single piece? Mine is an alpine unit. I removed the rear bracket too. But sits around 4mm high. I think I’m gonna cut the clock so it can sit flush.
Mine is a single piece including the vents and clock. I have a pioneer head unit. I did read on here people needing to apply a heat gun to the vent pipes behind to give themselves an extra 5mm. It is very tight and if i take it apart again I’ll do this to give a slightly better fit. I also did read of someone filing off a bit from the clock. 2008 Defender 110 XS SW - M57N2 / 6HP28X
Have a read here ..
https://www.defender2.net/forum/topic54225.html 2008 Defender 110 XS SW - M57N2 / 6HP28X |
I think I’m gonna dremel and cut few mm off the clock. Anyway thanks for the help.
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 ![]() ![]() ![]() |
I had to cut about a 1cm triangle Off the bottom corner of my clock to get the top vent part to sit right. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp Roy |
Tegner Member Since: 31 Jul 2018 Location: Alnwick Northumberland Posts: 189 ![]() ![]() ![]() |
I fitted a Pioneer Avic - F60DAB into a one piece DD unit extended the cables to the new switch panel using through crimps & had to cut the clock there is a u tube video on the complete installation
What sort of size cable do I need to get to extend the loom? Cause I’m planning to do some switches of spotlights to the cubby box. Thanks.
I used the same size that was already installed, Halfords sell small spools in various sizes
