Home > Puma (Tdci) > Puma half shafts
Page 1 of 5 12345>
Vitesse
Puma half shafts
Hi all. Does anyone know if the very late or last of line models were fitted with one piece/flange rear half shafts?
I have heard this to be the case but am struggling to find details. My own 90 was built in jan 2015 and does not have these fitted. They are wearing out and want to replace but just checking options. Many thanks. πŸ‘ 2015 90 XS Santorini Black
Post #747468 26th Dec 2018 9:49pm
Yes they were. They are exceptionally expensive.
Post #747471 26th Dec 2018 9:55pm
Best two options are genuine 1piece or Ashcroft HD 2 piece and HD flanges. I have the latter.
It'd be interesting to see what mileage people get out of the 1 piece.
Thumbs Up TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #747472 26th Dec 2018 9:58pm
WindyJ
During my research last month i found out that some very late models had the single piece ones fitted and sometimes under warranty if owner insisted. I discovered genuine ones are stupid expensive so went Ashcroft route with their HD flanges and halfshafts, 100% happy and come with 5yr warranty against wear.
Post #747476 26th Dec 2018 10:17pm
Vitesse
Thanks for the replies. I think the Ashcroft route is likely........ mine have survived 50k but getting a bit worn now πŸ‘ 2015 90 XS Santorini Black
Post #747478 26th Dec 2018 10:25pm
I’m very pleased with Ashcdoft too.
Blackwolf above previously mentioned how long his lasted, IIRC it was around 100k but sketchy memory on that.
Mine has never had 1 piece to pass comment, but of course they will still wear just depends on comparing estimated longevity really.
Bear in mind there is no warranty on β€˜fretting’ though. TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #747485 26th Dec 2018 11:05pm
The one piece shafts won't wear as there is no joint to 'fret'. Darren
Post #747491 27th Dec 2018 6:09am
LR90XS2011
lots of the mk 1 discoveries had single piece ones the cheapest source of them is a local scrap yard, generally they show no wear at the differential end DEFENDER 90 TDCI XS,
Post #747492 27th Dec 2018 6:18am
foggydave
United Kingdom 2014 Defender 110 Puma 2.2 USW Bonatti Grey
As the splines on both ends of the shaft are free to move laterally and they run with a fixed distance between joints. Would it be feasible to weld the outer housing to the end plate to achieve the equivalent of a one-piece shaft? Any axial movement would be taken into account with the free joint at the differential end.
Post #747498 27th Dec 2018 7:39am
AndrewS
Is the drive flange made of cast iron? If so then it would be difficult. 130's have feeling's as well you know Smile
Post #747521 27th Dec 2018 10:48am
Mo Murphy
I changed to one piece rear half-shafts in my 200 because I was fed up with drive flange wear, they have lasted 40,000 miles, were second-hand from a high mileage rusty 300 tdi Disco being broken and at the moment show negligible wear at the diff end.
Buy shiny ashcroft half-shafts if you must have shiny but I paid Β£15 for the pair πŸ˜†
50 Shades of Pennine Grey
Post #747526 27th Dec 2018 11:02am
This was the end I meant, but as it's diff oil lubed can't be very much of an issue and being only one splined component reduces wear.
The 1 piece however is significantly more expensive. TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #747536 27th Dec 2018 11:44am
jst
i fitted Ashcroft shafts originally with std DM but then changed DMs to theirs to stop water ingress. I fitted ashcrofts as i have lockers front and rear. Otherwise Mo's option is the most sensible. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #747590 27th Dec 2018 5:39pm
Roy5695
Shoot me down but the Britpart onepiece rear shafts have come very well recommended to me by a reputable garage. One of his customers has travelled across many continents with them fitted and no problems. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #747607 27th Dec 2018 6:27pm
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
I had mine professionally welded roughly 10,000 miles ago and have had no problems.
Post #747628 27th Dec 2018 7:47pm
Page 1 of 5 12345>
