Home > Puma (Tdci) > Puma half shafts |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17386 |
Yes they were. They are exceptionally expensive.
26th Dec 2018 9:55pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20375 |
Best two options are genuine 1piece or Ashcroft HD 2 piece and HD flanges. I have the latter.
It'd be interesting to see what mileage people get out of the 1 piece. $W33T $0U7H3RN $UG4R ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
26th Dec 2018 9:58pm |
WindyJ Member Since: 18 Oct 2018 Location: France Posts: 190 |
During my research last month i found out that some very late models had the single piece ones fitted and sometimes under warranty if owner insisted. I discovered genuine ones are stupid expensive so went Ashcroft route with their HD flanges and halfshafts, 100% happy and come with 5yr warranty against wear.
26th Dec 2018 10:17pm |
Vitesse Member Since: 21 Mar 2014 Location: Sussex Posts: 381 |
Thanks for the replies. I think the Ashcroft route is likely........ mine have survived 50k but getting a bit worn now ๐ 2015 90 XS Santorini Black
26th Dec 2018 10:25pm |
Iโm very pleased with Ashcdoft too.
Blackwolf above previously mentioned how long his lasted, IIRC it was around 100k but sketchy memory on that. Mine has never had 1 piece to pass comment, but of course they will still wear just depends on comparing estimated longevity really. Bear in mind there is no warranty on โfrettingโ though. $W33T $0U7H3RN $UG4R ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช Last edited by custom90 on 27th Dec 2018 11:40am. Edited 1 time in total |
26th Dec 2018 11:05pm |
The one piece shafts won't wear as there is no joint to 'fret'. Darren
27th Dec 2018 6:09am |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3641 |
lots of the mk 1 discoveries had single piece ones the cheapest source of them is a local scrap yard, generally they show no wear at the differential end DEFENDER 90 TDCI XS,
27th Dec 2018 6:18am |
foggydave Member Since: 29 Nov 2012 Location: Midlands Posts: 263 |
As the splines on both ends of the shaft are free to move laterally and they run with a fixed distance between joints. Would it be feasible to weld the outer housing to the end plate to achieve the equivalent of a one-piece shaft? Any axial movement would be taken into account with the free joint at the differential end.
27th Dec 2018 7:39am |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3707 |
Is the drive flange made of cast iron? If so then it would be difficult. 130's have feeling's as well you know
27th Dec 2018 10:48am |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2229 |
I changed to one piece rear half-shafts in my 200 because I was fed up with drive flange wear, they have lasted 40,000 miles, were second-hand from a high mileage rusty 300 tdi Disco being broken and at the moment show negligible wear at the diff end.
Buy shiny ashcroft half-shafts if you must have shiny but I paid ยฃ15 for the pair ๐ Mo The Land Rover 90 - Many are called, few are chosen. 50 Shades of Pennine Grey |
27th Dec 2018 11:02am |
This was the end I meant, but as it's diff oil lubed can't be very much of an issue and being only one splined component reduces wear. The 1 piece however is significantly more expensive. $W33T $0U7H3RN $UG4R ๐ฌ๐ง๐ด๓ ง๓ ข๓ ฅ๓ ฎ๓ ง๓ ฟ๐ด๓ ง๓ ข๓ ท๓ ฌ๓ ณ๓ ฟ๐ด๓ ง๓ ข๓ ณ๓ ฃ๓ ด๓ ฟ๐ฎ๐ช๐บ๐ธโฝ๏ธ๐ข๏ธโ๏ธ๐งฐ๐ช |
27th Dec 2018 11:44am |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8030 |
i fitted Ashcroft shafts originally with std DM but then changed DMs to theirs to stop water ingress. I fitted ashcrofts as i have lockers front and rear. Otherwise Mo's option is the most sensible. Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
27th Dec 2018 5:39pm |
Roy5695 Member Since: 15 Feb 2014 Location: Cornwall Posts: 1123 |
Shoot me down but the Britpart onepiece rear shafts have come very well recommended to me by a reputable garage. One of his customers has travelled across many continents with them fitted and no problems. 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp Roy |
27th Dec 2018 6:27pm |
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 834 |
I had mine professionally welded roughly 10,000 miles ago and have had no problems. Click image to enlarge |
27th Dec 2018 7:47pm |
