Home > Maintenance & Modifications > Spring Thing |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2414 |
You could use spring isolators in the back of a 90. However they are around 10mm thick. Or 1 inch spring spacers. Puma 110" SW
13th Dec 2018 3:00pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5688 |
If you are happy with everything, apart from the look, just fit spring spacers. Gwyn Lewis sells a large range so you can do what you wish.
13th Dec 2018 6:03pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3672 |
I may have a pair of 1” spring spacers going free over the Christmas period. Yours if you want them?
13th Dec 2018 6:26pm |
rockster57 Member Since: 15 Nov 2014 Location: West Yorkshire Posts: 937 |
Co1 that is very generous, thank you. Will PM you
13th Dec 2018 7:05pm |
Thank you all for your input. Going to try the spacers first of all. Much cheaper than new springs - especially with Co1’s kind offer.
13th Dec 2018 7:07pm |
