Home > For Sale & Wanted > [Wanted] TD5 Wing |
130dreamer Member Since: 29 Feb 2008 Location: Romford Posts: 100 |
Pretty sure I have one for a late TD5, will dig it out at the weekend and get some photos for you.
22nd Nov 2018 8:07pm |
1989964 Member Since: 11 May 2014 Location: cheltenham Posts: 57 |
Thanks mate i'll keep out an eye
22nd Nov 2018 8:24pm |
NickMc Member Since: 01 Oct 2014 Location: Norn Iron Posts: 1624 |
I think I’ve a few brand new genuine panels, but pre Td5- you can cut the holes out bigger though?
23rd Nov 2018 6:47pm |
L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 10742 |
^^^ that means they will fit my Tdi Nick 1996 Golf Blue 300Tdi 110 Pick up.
Keeper. Clayton. |
23rd Nov 2018 7:56pm |
Will fit up to end of the 200tdis, 300’s have a larger hole for the “plug” in econoseal type lights and two square holes for the screws, changed them to fit many times just a little work with a rotary burr, drill bit for the screw holes the make the hole square with a small triangle mini file....bobs your mothers brother. Td5 is the same, but has a square hole in behind the facelift headlight surround louvres.
23rd Nov 2018 9:56pm |
Thanks Nick
25th Nov 2018 10:05am |
