Home > Puma (Tdci) > Interior light staying on |
BenB8man Member Since: 22 Mar 2017 Location: Norfolk Posts: 429 |
If you're sure the door switches are ok, the only other switch I can think of is on the light itself.
You'll find that you have a red light on your rev counter if one of the door switches is showing open too, worth looking out for. |
13th Oct 2018 4:02pm |
Co1 Member Since: 19 Aug 2018 Location: North Yorkshire Posts: 3675 |
Checked them both at the switch and that way: red light flashjng when doors open, goes off when closed.
13th Oct 2018 5:34pm |
barbel jim Member Since: 12 Dec 2012 Location: Northants Posts: 1423 |
Mine was water ingress
It wouldn't always lock or alarm either |
13th Oct 2018 5:55pm |
That’s what I suspect as it happens after rain! The door switches were bone dry when I checked today and it had been down all morning!
13th Oct 2018 6:13pm |
KelvinB Member Since: 17 May 2018 Location: Crickhowell Posts: 24 |
I had the same problem just a few days ago - When locking with the remote, it would lock and then unlock again as it thought one of the doors was still open. Just pushed each door sensor a few times and it's been ok since. |
13th Oct 2018 7:12pm |
Still struggling with this. Checked the door switches and I’m confident it isn’t them, for starters the alarm doesn’t sound andit would if the door switches were made. Have checked the light units themselves and all appears ok. Havigflowed the wiring diagram, the light is switched at the ecu, so maybe an issue here? Any thoughts or anything else to check?
Col |
10th Nov 2018 9:41am |
Clive Member Since: 21 Mar 2014 Location: Littleborough Posts: 467 |
The door switches are only switching a very low current input to the alarm ECU and not the power to the lights directly, I just measured it on mine and it's less than 8mA, at this current level, it's quite feasible that a bit of moisture in one of the pin switches, or in the wiring in the door pillars or roof could cause it, don't forget the one on the back door too.
10th Nov 2018 11:38am |
If it was the door switch, would that not trigger the alarm to go off?
10th Nov 2018 11:48am |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20367 |
What light fixture is in place the standard incandescent bulb or LED? $W33T $0U7H3RN $UG4R
10th Nov 2018 12:50pm |
All standard.
10th Nov 2018 12:58pm |
Don't forget the bonnet switch as well.
It does seem to be a form of Earth leakage, as they are Earth switched there is a ground path being established and likely via moisture as suggested. Try pushing in the sensors then quickly releasing them to spring back, they can also tend to get gummed up in damp weather. $W33T $0U7H3RN $UG4R 🇬🇧🏴🏴🏴🇮🇪🇺🇸⛽️🛢️⚙️🧰💪 |
10th Nov 2018 1:04pm |
After this went away and came back a few times, I went over a bump and the lights came on. I gave the front light a knock and it went off again, took the cover off and it was full of cobwebs and dead insects!! Cleaned them out an hey pesto! All good! Who knew!!?
25th Nov 2018 11:32am |
pme Member Since: 06 Jan 2016 Location: cambridge and mainly ariege Posts: 49 |
27th Nov 2018 2:48pm |
