![]() | Home > Maintenance & Modifications > Headlights (again) - Not LED but how about HID Xenon? |
How bloody irritating! ![]() Have to confess to ripping out the cheaper version of this loom as it did a fab job of melting last winter. When working and combined with the crystals and nightbreakers it was fantastic. Did anyone else find they were going through bulbs quicker - every 12 months or so. |
Brendan once again thank you for the schooling
Just to put a bit more flesh on my above post.
Finding the B3 and Tc figures sometimes requires a little bit of digging. Osram Night Breaker Laser . B3 . 150 hours, Tc . 300 hours Osram Night Breaker Silver . B3 400hr . Tc 650 hours . Yes there is a lot of other data associated with headlight bulbs but those figures are just to show the differences in life span of bulbs from the same manufacturer and their same range. Have not checked all the other data. So when looking at different bulbs please look more closely not just at the light output figure but at the anticipated lifespan. Brendan |
Matt_H Member Since: 19 Sep 2018 Location: Cornwall Posts: 42 ![]() ![]() ![]() |
Yes it was rather! Next time round (if there is one) i'll make my own up - some of the connectors inside the H4 blocks were bent too so I had to have a poke about with them to be able to get the bulbs in. For the fifty quid it cost to buy and get posted, I can do something myself with the right length cables to be able to run it so it looks a bit more "factory fit", and also have the relay block somewhere that its secure & I can see it and get to it. Sadly my relay block is sat on its side in between the airbox and its inner wing mount and I got a cable-tie near it (tie-in the alternator feed run to the bonnet release cable) to stop it from moving around - not ideal but the best I could do. Still, all done now. ![]() |
Interesting! Thanks ![]() I got Night Breaker "unlimited" (whatever that means!?) Looks like I could have gone brighter ![]() https://www.amazon.co.uk/gp/product/B00EPL...&psc=1 ...might grab some spares ![]() |
BuckBlu110 Member Since: 19 Apr 2014 Location: in the pub Posts: 719 ![]() ![]() ![]() |
Now here’s a query for you Brendan, picked my dcpu up from mot this afternoon, it is fitted with genuine trucklite led head lights, and the tester said that leds are bundled in with hids and xenons in that they should have washers and the vehicle have self levelling suspension to make them legal, so by rights he should fail the motor because it isn’t fitted with either. He didn’t fail it thankfully because he said we’re that they were perfectly aligned and he didn’t think they were going to cause any issues.
Is this right? Have whoever’s in charge of mot rules snuck this in with the revisions made earlier this year? |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17610 ![]() ![]() ![]() |
According to greyhead.co.uk :-
So it seems that under European (ECE) law you cannont fit LED lights unless you also fit levelling and washing systems. Whether this is a UK MOT test failure is a different matter. It is also questionable whether by fitting such units whether approved or not you are invalidating the Whole Vehicle Type Approval for the vehicle. I suspect that you are. Massively complex. Good bye, good old days of simplicity! ![]() |
SJM2018 Member Since: 06 Jul 2018 Location: Bristol Posts: 296 ![]() ![]() ![]() |
https://gear.landrover.com/gb/en/defender/...tiary-tabs
Land Rover sell a Xenon bulb upgrade kit for 07MY onwards. Has anyone used / heard about this? |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6641 ![]() ![]() ![]() |
Simply a pair of Ring Xenonmax H4 bulbs, available for £16ish a pair elsewhere.
https://www.amazon.co.uk/Ring-XenonMax-Hea...B002Z7R4HS https://www.ebay.co.uk/itm/Ring-Xenon-Max-...1975664706 ![]() ![]() |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4242 ![]() ![]() ![]() |
Those are just uprated H4 bulbs with Xenon gas. Like Phillips White vision or similar road legal upgrades. 2007 110 TDCi Station Wagon XS
Maybe the approved aftermarket ones don't exceed 2000 lumens??? No idea, just a guess, as that would avoid the need for headlamp cleaning. 2007 110 TDCi Station Wagon XS |
Somewhat relieved that I have opted for the loom and halogen option, having read that ![]() |
My Trucklites pass the MOT, only comment was they have a flat became pattern which he doesn’t often see. Didn’t mention it was a problem. 2007 110 TDCi Station Wagon XS
Am trying to think of the politest way of saying this! Maybe you need to find another MOT tester as he will be wanting to fail every vehicle which has LED headlights fitted at the factory which does not have factory fitted wash wipe system. IF and I repeat IF a vehicle has LED headlights AND has headlight cleaning system then they must work, otherwise it is a major defect. If the vehicle has LED and does not have a cleaning system it is not a failure as there is no requirement under 4.1.6 All the last Defenders special editions had LEDs fitted without wash wipe systems and the 70th editions i.e. 2015 models are being retro fitted with Nolden LED headlights. Now I wonder what your MOT tester would say if you ask him to explain the markings on your Truck-Lites, what does the light function code means and what is the Peak Beam Reference Number etc. For the reputable LED headlight manufacturers such as Nolden, Vision X, Truck-Lite, J. W Speaker are all approved headlights and are all legal to retro fit into Defenders without any modifications as long as the aim is correct. The reason being they are all approved and the dip beam is kept below 2,000 lumens avoiding the need for wash wipe systems Now I wonder if your MOT station is going to invest in light flux measurement equipment? Under the EC directive for roadworthy periodic testing of vehicles there was a requirement for testers to check the markings on headlights. This was not included in the UK MOT, more the pity in my view as it would get rid of the cheap illegal headlights. Now some headlights have a inbuilt indicator and if they have the correct approval are road legal, BUT at the front of a car you are only allowed one indicator per side. Having two or more indicators per side at the front is NOT an MOT failure but is illegal, the MO T only checks that they work. Now I know I stress the importance of approval marks and that it is best to stick to reputable brands which have the manufacturers name on the lens. It took me less then 20 seconds to find some LED headlights which are not approved and also boasted dip beam output of 2,300 lumens. Guess what illegal as no approval marks and no advice to fit wash wipe system. Yes it may cost more money to get road legal approved headlights. Now I wonder what your motor insurance company view will be if you have a claim and they find out your vehicle is not road legal?? Brendan |
