Home > Technical > OMG (D44) supplied OME….fillet weld failure
landydubai
United Arab Emirates 2009 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Big Cry OMG (D44) supplied OME….fillet weld failure whist out in the Dunes! The weld failed and sheared off the fuel filter delivery hoses….before you ask under normal articulation ! The weld just sheared off see photos, anybody had the same experience with OME ??? Spent (3) hours getting it to the road side .
Shocked LandyDubai
Keep the shiny side up!
09 110 XS BAS remap
09 90 pick up BAS remap
08 D3 V8 G4 Spec
Bentley Speed GT 2009
G55 2003
Ford Raptor 2010 - new toy!
Post #73320 29th May 2011 11:38am
MK
Yes, I have heard that happend with OME and others. Therefore, offroader use pin-pin mounts. They resist better. On the other hand you can repair it easily. Puma 110" SW
Post #73326 29th May 2011 1:11pm
double cab happy
England 2007 Defender 110 Puma 2.4 DCPU Java Black
on standard shock,
Embarassed following my 14 year old lad in disco 4,
he will never let me forget it
Post #73327 29th May 2011 1:16pm
Landy nut
United Kingdom 2006 Defender 90 Td5 PU Epsom Green
Yep, I am hearing more and more reports of poor Old Man Emu shocks now and have seen several to look at in the flesh. They all appear to be manufacturing faults and poor quality control. Thats the exact reason why I am going Koni. Better build quality, better finish and generally a better all round shock. I am afraid we are beginning to see this sort of thing creeping in everywhere. A manufacturer puts out a really good product and gets a loyal following, almost to the detruitment of the rest of the manufacturers and then for some reason they start to cut corners here and there to make bigger margins.
I really hope you manage to get it all sorted out soon mate and that you are back up and running at fully capacity soon.
Post #73333 29th May 2011 2:49pm
Anderzander
I've come across this where the bush has been over tightened or the washers fitted in such a way as to restrict the movement.
Post #73334 29th May 2011 2:55pm
dgardel
Italy
Seeing the welding point..........
Very tiny.........
Shocked Shocked Shocked Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #73336 29th May 2011 2:55pm
mick
Looks like poor welding just looks like they have tacked it would have thought it needed welding all the way round for something that's going to get some hammer.
Post #73354 29th May 2011 5:55pm
Landie Boy
United Kingdom 2010 Defender 110 Puma 2.4 USW Stornoway Grey
Send the pics of to OME, they should pay to have any damage fixed.
Jack
Post #73359 29th May 2011 6:33pm
ti-fat-man
United Kingdom 2011 Defender 110 Puma 2.4 USW Alpine White
ohh Censored ... Shocked
i've only just got mine back on the road after my recent mis-hap...
i can certainly vouch for that filter area being a tad on the vunerable side. now i'm worried about my suspension 'up-grade' Shocked ...now if anyone knows where to get a standard height, pin-pin rear mount, i'd love to know... Thumbs Up
Post #73366 29th May 2011 7:05pm
big steve
United Kingdom 2015 Defender 90 Puma 2.2 HT Montalcino Red
devon 4x4
gwyn lewis
they are much the same but up 2 your spec
regards steve 2015 2.2 tdci hardtop xs
3.2 conversion DONE 238bhp and 707nm torque and thats just the start ;-P
hybrid turbo in build -done ready to fit
ashcroft atb in transfer box
6 speed auto in build
Post #73368 29th May 2011 7:26pm
BigMike
ditto.
Post #73384 29th May 2011 9:21pm
CFB
Don't know if Terrafirma do what you want but I have just fitted a set to my D2 and they are superb in every respect, road manners are brilliant, composed and controlled whilst retaining a comfortable supple ride, off road they are brilliant too, can't recommend them highly enough and very reasonably priced too. Andy
Post #73425 30th May 2011 9:55am
cobs
United Kingdom 2007 Defender 110 Puma 2.4 XS CSW Cairns Blue
what model?
Post #73527 30th May 2011 9:18pm
CFB
I use the 'All Terrains', the D2 is lifted by 2" but they work well at standard or lifted heights (albeit with slightly limited travel at full stretch obviously), can't praise them enough, they are superb products. Andy
Post #73531 30th May 2011 9:25pm
AndrewS
BigMike wrote:
ditto.
ditto this ditto Thumbs Up 130's have feeling's as well you know Smile
Post #73593 31st May 2011 2:58pm
