Home > Maintenance & Modifications > Headlights (again) - Not LED but how about HID Xenon?
Page 2 of 4 <1234>
Retroanaconda
Bluest wrote:
In my view the best value totally legal option is the Landreiziger loom, Osram Nightbreaker H4 bulbs in Wipac Crystal headlights. Lots of people have done this, including me, and there is concensus that it works well. You could easily do the whole lot for less than £100. The only tricky bit is skinning your knuckles trying to get the loom connected to the alternator positive. The rest of the wiring is plug and play.
One other thing, when you’ve changed the headlights for whatever you end up getting, get the beam set by a garage as that can make a big difference. My local place only charged a tenner to do it.
100% agree with the above. It's the setup I have and the lights are fantastic. I do a lot of miles on very dark and fast roads in the Highlands and have never found myself thinking that the lights were inadequate. The poor performance of the factory setup is in my opinion 80% down the wiring, so the Landreiziger loom makes a big difference even on its own. A decent set of bulbs installed in good condition standard units, kept clean, does the rest.
Frankly LEDs or HIDs are expensive, unnecessary, look ridiculous and are prone to dazzling oncoming drivers. But opinions vary, of course, and the bling factor holds a great value these days.
No need to get a garage to align your headlights though, just park against a flat wall and do it the way described in the workshop manual with a tape measure Thumbs Up
Post #730154 20th Sep 2018 2:22pm
dorsetsmith
Post #730158 20th Sep 2018 3:06pm
Or stick it in Halfords and they'll save you the hassle for about £10 or so.
They done mine well, where the main dealer couldn't!
HID's are now old school really, high current consumers very hot and illegal.
LED or Halogen upgraded with upgrade loom is the best.
Both have similar output, only one is more efficient (LED.)
Individual choice really, I'm happy with my black Noldens. TheThunder Rolls🇬🇧🇺🇸
Post #730161 20th Sep 2018 3:24pm
Martin
Site Admin
What are the measurements for "A" and "B" in the diagram above?  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #730163 20th Sep 2018 3:26pm
dorsetsmith
the beam centres `A` are measured horizontally on vehicle and dimension ` B ` vertically from the ground
work too went through MOT no adjustment needed Whistle
Post #730167 20th Sep 2018 3:51pm
geobloke
Assume A= distance between centre of headlights and B= height from ground to centre of headlights.
Post #730169 20th Sep 2018 3:54pm
apt100
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Aintree Green
Martin wrote:
HID need some sort of automatic levelling system to be legal as well. Which is why you couldn't get Xenons on a coil-sprung Discovery 3 - the air suspension is used to level them.
I could be wrong (this is a question not a statement) but don't Xenons and/or HID also need a headlamp wash system?
Post #730186 20th Sep 2018 5:53pm
Retroanaconda
Halfords! Good one - I wouldn’t trust the ‘mechanics’ there to sit the right way round on a lavatory Laughing
Post #730253 20th Sep 2018 9:23pm
Yes, they do. Automatic levelling and a washer system are legal requirements.
Post #730257 20th Sep 2018 9:42pm
Matt_H
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Zambezi Silver
Thank you all for your further inputs. I am very happy to be guided by your suggestions on the loom and "nightbreaker" set-up and will give that a go.
@Brendan, Further thanks, and yes I'm aware that the product I linked to was US spec / not great As I said earlier, I was just exploring the principle that if you could get an enclosure that was designed for HID (not necessarily this particular one, it was just the first one I found), then could you fit HID bulbs - that would seem to be compliant with the regulation you quoted before? No idea on the self levelling requirement etc.. the Deefnder has levellers, but they are manual from a switch.
Cheers,
Matt.
Post #730275 21st Sep 2018 6:54am
apt100
Thanks for confirming.
Post #730338 21st Sep 2018 3:11pm
Thanks for posting this! It prompted me to remember to set my headlights up, having taken them out for something earlier in the year. Works a treat. Darren
Post #730401 21st Sep 2018 7:26pm
Matt_H
Hi again all,
So I've got all the bits:
landreiziger lighting loom
clear wipac lenses
nightbreaker bulbs.
..and its a nice day so thought I'd get on with this.
Immediate problem thoughh! How on earth do you make the loom connection to the alternator on the 2.4 puma - I cant even see the connector let alone get close to it !? Big Cry
Post #734007 10th Oct 2018 12:04pm
Matt_H
Ok so I've managed to get to it.
Have to say I'm really not that happy with the Landreiziger loom. I see that the quality looks good, but the lengths are all wrong.
There is barely enough length in the cross-car cable to be able to tuck it tidily across the top of the rad, and in doing so it means that the relays end up floating loose behind the airbox. This in turn gives you barely enough to get to the alternator.
I assume it was desgined for a TD5 - needs tweaking to be a good tidy fit in a Puma 2.4 : (
Post #734017 10th Oct 2018 12:54pm
Matt_H
...its all because of the airbox - its exactly in the space where the relays are fitted in to in the landreiziger video. I'm going to end up with a crappy maintenance solution where I need to remove the headlight assembly the get at the relays, which are going to have to just flap about in front of the airbox (or I'll manage to cable tie them in there somewhere)
Wasn't expecting this : /
Post #734022 10th Oct 2018 1:03pm
Page 2 of 4 <1234>
