![]() | Home > Puma (Tdci) > puma rear side sliding window removal |
Maxxed_Ross Member Since: 06 Jun 2012 Location: Bathgate / North Sea Posts: 340 ![]() ![]() ![]() |
Normally it's just a case of pulling the rubber filler strip out then drilling the rivets. I've not idea what would be different about a Puma though
this is quite a good video on how to do it... granted on a non-Puma. The theory should be the same though 2013 Discovery 4 HSE Lux | 2001 Defender 90 TD5 | 2007 Prodrive RB320 |
Balvaig Member Since: 19 Feb 2016 Location: Fife Posts: 736 ![]() ![]() ![]() |
Never had to remove one, but I think the Puma side windows are bonded in and are difficult to remove. I read somewhere that you had to use heat and fine nylon string to break the seal.
Certain others will be along with more details. |
Tdi4 Member Since: 24 Oct 2014 Location: Houten Posts: 513 ![]() ![]() ![]() |
Jup, they are glued/kitted.
You have to use a string saw to get them out. Not to difficult you just have to take your time. a defender from 1984 pretending to be a puma with a touch of Range Rover |
zsd-puma Member Since: 09 Aug 2016 Location: Kent Posts: 2720 ![]() ![]() ![]() |
a windscreen removal knife probably does them too.
big110 Member Since: 02 Nov 2016 Location: Sweeden Posts: 342 ![]() ![]() |
Well interior trim is off but what a PAIN to break the silicone seal. 1/2 hour just to get the bottom one done.
