Home > Puma (Tdci) > New release bearing and valve
MK
Did LR changed the following parts when started to "build" the 2.2?
LR068981 Adapter Cutch Slave Cylinder. Not sure if changed
LR068982 Valve - Control - Clutch Slave Cylinder. Used to be made of metal
LR068979 Clutch Slave Cylinder. Not sure if changed Puma 110" SW
Post #721876 7th Aug 2018 1:08am
As far as I know there is no difference between the 2.4 and 2.2 for the parts you list. My 2007 2.4 has a plastic flow restrictor valve, and I have never seen a metal one.
Post #721902 7th Aug 2018 7:51am
