Home > Puma (Tdci) > Engine Squeal
rleslie
Scotland 2007 Defender 110 Puma 2.4 XS CSW Epsom Green
Engine Squeal
Hello. I'm after some help. I'm currently touring wales which is 500 miles away from my local garage...hence the silly question. My 2.4 Puma 110 has developed a squeal.... no sound when idoling, but when any load on the engine the sound appears. It does also sometimes go off completely too, then when I press the accelerator it re-appears.
I've no mechanical knowledge.....but could it be a water pump or some sort of fan belt? The engine temprature has not been affected so far. The squeal happen when the engine is cold too......
Is this something I can keep going with until it dies and hopefully I get home to Scotland, or is this something I need get fixed ASAP...Do not drive any further as may cause thousands in damage????
Post #721316 3rd Aug 2018 8:28pm
Sounds like a slipping Aux drive belt, not very expensive and easy to change over really.
(There is an aircon and non aircon version. Idea )
You won't be able or tick it off the possible culprit list until changed over but I would only do it at earliest convenience.
Thumbs Up $W33T $0U7H3RN $UG4R
Post #721318 3rd Aug 2018 8:32pm
williamthedog
Probably belt as Steve mentioned or possibly the tensioner as well. Where about in Wales are you?
Post #721320 3rd Aug 2018 8:47pm
Muddybigdog
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Zambezi Silver
Possibly intercooler hose split, Jumped ship to reliability - Mitsubishi L200
Puma 90 XS - Sold
D3 - 2.7 S x2 (both Sold)
Freelander 2 HSE - Sold
Freelander 1 - Sold
Disco 2 - Sold
Post #721321 3rd Aug 2018 8:47pm
rleslie
Thanks guys. It sounds more like a belt than a whirring air noise. We are up beside Caernarfon. I’ll have a google for an independent Landy garage, that should hopefully diagnose the issue and give some advice.
Thanks
Post #721338 3rd Aug 2018 9:48pm
LR P/N's of for the Acc drive belt on the 2.4 motor with air con: PQS500600
Without air con: PQS500610
Air con version is longer, other than this they are identical.
Thumbs Up
Price under £50, you can change youself easily. $W33T $0U7H3RN $UG4R
Post #721343 3rd Aug 2018 10:07pm
AndrewS
Have you had a remap or a tuning box fitted? It could be the turbo gasket Question 130's have feeling's as well you know Smile
Post #721374 4th Aug 2018 8:30am
rleslie
Yes, I've had a remap and air box mods.
I'm just concerned that if it breaks it will cause more damage...
Post #721382 4th Aug 2018 9:12am
windy81
Wales 1992 Defender 90 200 Tdi HT Firenze Red
this might help. Only 30 mins away from Caernarfon, talked to him a while ago and was very helpful.
https://www.facebook.com/RustyNuts4x4/
Post #721399 4th Aug 2018 10:55am
AndrewS
If its the turbo gasket see here http://www.defender2.net/forum/topic457.html?highlight=turbo There has been some developement in new gaskets I think. 130's have feeling's as well you know Smile
Post #721401 4th Aug 2018 11:21am
jst
Take the belt off and see if it still does it. If the noise stops it's either the belt, an idler, or a pulley itself. If the noise still continues and I would look at other things like AndrewS suggests possibly turbo gasket Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #721479 4th Aug 2018 7:50pm
zsd-puma
Spraying a little bit of wd40 onto the belt can help diagnose it too, if it goes quiet you know it's the belt. You can also do the same with pulley bearings, obviously it wont last, but if it goes quiet after you've sprayed a particular bearing you know it's the problem.
Have a look around the belt area too, if you see bits of 'rubber dust' it's a good indication your belt is slipping.
Post #721502 4th Aug 2018 10:33pm
