![]() | Home > Puma (Tdci) > Electrical |
gadget tom Member Since: 22 Oct 2013 Location: banbury oxfordshire Posts: 4 ![]() ![]() ![]() |
Defender 110xs 2010.
Hazards not working indicator's work tell I press hazard switch then I have nothing. Can't find any blown fuses. Any ideas please. |
Could be the flasher relay. Take a look here from a couple of days ago:
http://www.defender2.net/forum/topic62841....zard+relay Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
I have changed relay still the nothing
Relay is working ok if your indicator's work ok ![]() Click image to enlarge if its not fuse 31 most likely be hazard switch itself YUG000180LNF Last edited by dorsetsmith on 3rd Aug 2018 7:44am. Edited 2 times in total |
Vitesse Member Since: 21 Mar 2014 Location: Sussex Posts: 389 ![]() ![]() ![]() |
I agree. Very likely the switch. I have spent some time on this recently converting to a Discovery 2 Hazard switch. The hazard switch is very cheap to get hold of as is used in a range of British vehicles. The only differences are the top cover orientation that can be swapped over
