Home > Maintenance & Modifications > MSS small window grills
Greyman110
Can anyone tell me how the rear small window grills fit please? Just picked up a second hand set so would like an idea of what's needed before I start pulling the trim off.
Also I'll be putting up some used sides and a rear (non-brake light) in the for sale section soon if anyone's interested.
Thanks
Post #720202 29th Jul 2018 11:52am
donmacn
It might depend on what car you have, whether there are already holes drilled to take the lower mounting bolts.
I fitted a pair easily enough - once I'd had the 'doh' or 'eureka' moment - depending on your point of view. When I first put one up against the window, I thought: "how am I going to get my hand in there to tighten the bolts?" But of course I was using the offside guard in the nearside window. If you try it, you'll see what I mean.
I think I put some pics on my 'tinkering' thread below. (Edit - yep, just a couple, on the 3rd page, but might be helpful)
Basically, the top linings need to be out to give access to the upper roof to side bolts. These should line up nicely with the upper bracket for the guard. If your car has existing holes under the window, then they should match up too. Mine didn't so I had to fit the top ones; mark where the holes should go at the bottom; remove the top ones again; drill; refit.
Not at all difficult once I'd realised they were sided... Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #720245 29th Jul 2018 3:30pm
Greyman110
Thanks for that. Looks like you did a nice neat job. What did you use to put in the holes you drilled for the bottom fixings? This is the first car I've ever had a go at doing things to so it's a learning curve!
Post #720250 29th Jul 2018 3:45pm
donmacn
I think you could just put a nut/bolt through it, but I used a 'rivnut'.
It's just a collapsible nut, works on the same principle as a pop rivet, but you're left with the threaded section. You need to have the rivnuts themselves, and a tool to set them, though there are other ways to do it. I guess I did it just because I could. I have the tool, and the nuts, and it seemed neater!
Like I say, I think you could easily use just a nut and bolt. You might need to be careful that you didnt overtighten that, and distort the sides. Or use some sort of packing piece in between them. Donald
in the past..
Post #720255 29th Jul 2018 4:04pm
Greyman110
Thanks... Good tip on the over-tightening! Thumbs Up
Post #720278 29th Jul 2018 5:23pm
wyvern
United Kingdom 2012 Defender 110 Puma 2.2 XS CSW Firenze Red
Re: MSS small window grills
Thanks
I may be interested in the side grills depending on price and condition (I and if they are MSS ones ) would like the rear one too but have a break light fitted ...
Thumbs Up Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Elgar -TDCI(Puma) 110XS Dormobile - now sold
Devon & Cornwall 4x4 Response - DC126
Post #720288 29th Jul 2018 5:45pm
donmacn
I have the rear guard fitted - and I'm about to fit an upper level brake light. I think I'll just modify the grill slightly by judicious use of a jigsaw. I can't see that it will particulary compromise the effectiveness of the guard. FWIW. Donald
in the past..
Post #720310 29th Jul 2018 7:20pm
wyvern
^ ^ ^ Thumbs Up Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #720316 29th Jul 2018 7:38pm
wyvern
Grayman - you have PM ! Thumbs Up Poppy - TDCI (Puma) 110XS 2.2 - Camper conversion - see the build here - https://www.defender2.net/forum/topic56530.html
Post #720466 30th Jul 2018 2:38pm
