Home > Maintenance & Modifications > Galvanising original side steps
justinp
Hi All,
I’ve recently taken my side steps off as the paint had started to bubble around the welds and lift on the corners.
I’ve cleaned up the welds and the rust was superficial, so I’m considering getting the side bars and supporting brackets shotblasted and hot dipped galvanised.
The cost to do the work is approx £200, so before I go ahead is this a waste of money? Are they likely to rust from the inside out?
Replacement bars can be picked up for not much more, but I’m guessing they may rust even quicker than the originals.
Let me know what you think.
Cheers - JustinP Now gone - 2012 2.2 110 DC XS
Post #718609 19th Jul 2018 5:56pm
Is that for other parts cost wise or just for the steps? If the latter it sounds expensive!
You wouldn't get rust inside with hot dip Galv, but you would need all cappings and accessories removed and possibly drill drain holes to aid the dipping process and avoid gassaeous explosions at the plant.
(They normally advise.)
I was seriously interested in Wedge Galvanizing as a company but never got around to it as of yet. $W33T $0U7H3RN $UG4R
Post #718614 19th Jul 2018 6:53pm
zsd-puma
the molten zinc will run inside the tubes, but you might have to drill a few more holes to let the zinc in and the air out.
Post #718635 19th Jul 2018 9:16pm
justinp
Are the holes at the end not big enough?
Post #718642 19th Jul 2018 10:02pm
On that size tube yes, check your other fittings too though. Thumbs Up $W33T $0U7H3RN $UG4R
Post #718643 19th Jul 2018 10:04pm
justinp
Good point, I hadn’t considered the other fittings. Now gone - 2012 2.2 110 DC XS
Post #718713 20th Jul 2018 11:25am
👍🏻 ZSD-Puma has it wrapped up really. It’s just to ensure there is no internal section that cannot release air and of course to allow molten Zinc in. As well as the explosive side.
They also do degreasing dipping etc and all that sort of thing. $W33T $0U7H3RN $UG4R
Post #718724 20th Jul 2018 12:11pm
Mdm
if you want them dipping you will have to remove all paint or powder coat before galv
good work by pillar wedge recently for me
Post #718983 21st Jul 2018 8:07pm
williamthedog
^^^^ mmm... Looks lovely Thumbs Up
Post #718987 21st Jul 2018 8:27pm
Tardis
Germany 2010 Defender 90 Puma 2.4 SW Santorini Black
£200 seems a bit over the top, I paid around €70 for sandblasting and galvanizing mine (Puma 90) two years ago:
After galvanizing they got an U-Pol Raptor coat.
Post #719456 24th Jul 2018 3:49pm
doublea
Scotland 2016 Defender 110 Puma 2.2 Adventure Phoenix Orange
What did you use to receive attach the treads? I couldn't find a supplier of the long rivets to replace the originals and had limited success with riv nuts. Current Steeds:
2015 110 UW in Grasmere Green
2003 BMW F650 the Hack
2000 Elise
1992 Ducati 888 (no longer in bits, yahoo)
1990 TDR 250 (in bits again)
1988 TDR 250 (no longer in bits) and for sale
Post #719568 24th Jul 2018 10:33pm
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
£200 Is way too much, shop around, it might be a big tank and they have a minimum charge 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top
1958 Series 1 Soft-top
Post #719570 24th Jul 2018 10:42pm
Tardis
If I remember correctly they were like 6,4mm x 20mm (similar to these but aluminium). My local landy garage fixed them because my one hand rivet gun can't handle rivets larger than 5mm.
Post #719595 25th Jul 2018 7:26am
sako243
£200 seems very expensive. It wasn't blasted (I attacked it with a wire wheel) but I had some sliders I repaired for a friend galvanised for him. Each weighted in at 38kg and cost under £30 to hot dip galvanise. Ed
82 Hotspur Sandringham 6x6
95 Defender 110 300Tdi
Post #719704 25th Jul 2018 7:04pm
Stacey007
I was looking at new steps as I'm fed up having to keep painting them...
I started sanding them down to paint before holidays and a hole appeared... eeek. so On my return it will be new step time.
£200 sounds a lot?
Standard new steps are around £235 for a 110 XS
Then a Zinc plated option for £330
Interestingly though the guarantee is a year for both? My plan is to go for either of these as I also would like a black tread plate like the fire & ice style. Then also fit front mudflaps to stop the crud catching and baking in on the steps rotting them.
https://www.sidesteps.co.uk/shop/side-step...ide-steps/
For now I've painted mine again even with the hole Smile
Post #719813 26th Jul 2018 10:36am
