Home > Puma (Tdci) > Inner seal rear axle
Tdi4
Netherlands 2008 Defender 110 Puma 2.4 CSW Stornoway Grey
Last monday i was repairing/replacing the inner seal of the rear axle.
On the left (with grey ring inside) is the new one. On the right is the old one (without grey ring).
So my question is. Should it be installed with the gray ring Or without?
 a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #710102 31st May 2018 10:39am
NickMc
Might help if you say what year/axle the car is/has and what part number the seal is?
Post #710143 31st May 2018 1:50pm
Tdi4
Defender 110 (Tdci) from 2008.
The part nr is: FTC4785G inner seal. a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #710151 31st May 2018 2:22pm
Tdi4
Bump. I still have to do the left side Whistle a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #710583 3rd Jun 2018 11:54am
I would imagine with, I would have thought it may be a superseded part improved as the ring will help the seal retain its shape.
Especially as you can see an outer and inner mating face, with the grey ring sandwiched between the two.
Many seals are notorious for going oval or going out of true, then the inevitable happens.
That would be my view on it at least. $W33T $0U7H3RN $UG4R
Post #710592 3rd Jun 2018 2:35pm
Tdi4
So install with the grey ring then? a defender from 1984 pretending to be a puma with a touch of Range Rover
Post #710596 3rd Jun 2018 2:49pm
