![]() | Home > Maintenance & Modifications > another headling question |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5115 ![]() ![]() ![]() |
You need to remove the original fabric and any sponge that it left stuck to the card. Then use a spray glue to stick the new covering. There is a member on here who sells the original OEM fabric Ibexman on this forum sells it. Fabric is 1.2 wide 12 metre plus p&p. PM him your requirements I think his phone number is. 07944349763 For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Maxxed_Ross Member Since: 06 Jun 2012 Location: Bathgate / North Sea Posts: 340 ![]() ![]() ![]() |
When i did mine the original was peeled off, the liner sprayed with high temperature caravan glue then stuck on some Gortex black fabric.
Once in a rough shape I folded the edges back and stapled them down and glued the edges as per the original Looks excellent, was really easy to do and best of all is now wipe clean! |
T140 Member Since: 15 Mar 2016 Location: Ayrshire Posts: 176 ![]() ![]() ![]() |
thanks for the replies, i was thinking of doing it black i have seen headlining material on the net at a reasonable price. nobody is perfect but being Scottish is a start
steveyorks Member Since: 08 Apr 2013 Location: west yorkshire Posts: 183 ![]() ![]() ![]() |
Note the use of high temp glue! It really makes a difference as if you use something else like Evostick it falls down after a few weeks even in winter.
