Home > Td5 > TD5 crankshaft STUCK
agw123
Just starting to rebuld the TD5 engine after having the cylinders rebored. Fitted the crankshaft with new bearings and torqued it down according to the manual but now it wont budge. Used a breaker bar to put some decent force behind it but it's completely stuck.
Anyone had this before and know whats wrong?
P.S complete novice just having a go
cheers Thumbs Up[/quote]
Post #694644 19th Mar 2018 2:14pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
You need to take it apart again by the sounds of it,
Check all your surfaces for damage, high spots etc.
Are you using oil on reassembly?
Cranks should turn “nicely” if fitted correctly, check and check again.
When stripping it back down, check as you start removing bolts, to see at what point it starts to loosen up,
This may then give you an idea of where the problem might be?
Thumbs Up 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #694657 19th Mar 2018 2:48pm
shropshiredefender
England 2011 Defender 110 Puma 2.4 USW Santorini Black
Had the same problem with a V8 I rebuilt years ago. I'd managed to get a small piece of swarf behind one of the main bearing shells. Cost a new set of shells but all part of the learning curve!
Be lucky Thumbs Up
Post #694665 19th Mar 2018 3:36pm
Laurie
Check that the new bearing shells are the correct size, not undersize.
Post #694666 19th Mar 2018 3:47pm
rallysteve
You should really be using plastigauge to check the clearances in the bearing journals is within spec
Post #694686 19th Mar 2018 5:00pm
