Home > Puma (Tdci) > Turbo Heat Sheild |
meeerrrk Member Since: 12 Feb 2017 Location: Surrey Posts: 548 |
During my on going quest to find the vibrations in my Defender, I found two heat shields very lose and rattling against the turbo.
For process of elimination, I have removed both, and to my amazement I noticed a huge difference right away. The first in question is the main turbo heat shield = it had 3 bolts into the manifold which were secure but it was simply flapping around and not secure. Is it safe to leave this heat shield off or do I need to find a way to re-instate it securely? The 2nd is a much smaller heat shield just below and rear ward toward the bulkhead - it has a metal clip to hold it on to whatever it should have been attached to. This was also flapping about "in the wind". It looks like maybe it should have been covering a sensor or connector of some sort; again, is this vital and should it be replaced, or is it ok to leave off longer term? Advice would be greatly appreciated - especially if anyone knows a good way to actually secure these things without them flapping about and causing unwanted and worrying noises! thanks Mark My 90 Project : http://www.defender2.net/forum/topic52774.html |
26th Feb 2018 12:54pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8030 |
i havent got a turbo heatshield on either of mine, 80k on both. Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
26th Feb 2018 1:38pm |
Thank you Blackwolf, that is very useful information, much appreciated My 90 Project : http://www.defender2.net/forum/topic52774.html |
26th Feb 2018 1:50pm |
Good news, i'll see how it goes then. At least I know I don't have to rush to refit it. My 90 Project : http://www.defender2.net/forum/topic52774.html |
penny washers and stainless cable ties usually secure them nicely.
Bear in mind cars are designed for use in climates much hotter than in the UK, where such shields are possibly essential. In colder climates you can probably get away without them. |
26th Feb 2018 6:00pm |
