Home > Td5 > 120 kph warning light (Alternate use) |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2227 |
I use the warning light for my cruise control. Unfortunately however it requires connection to earth to illuminate rather than a positive signal so most applications will require a relay to switch it on.
Steve 02' 110 TD5 Double Cab Rebuild Thread |
19th Feb 2018 3:41pm |
4RF RDS Member Since: 19 Jul 2015 Location: Ottawa Posts: 932 |
I figured that would be the case as I use my choke warning for the heated screen. Which wires though? Do you know? My wiring diagrams do not show this warning light ā¹ļø 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
19th Feb 2018 4:07pm |
Pin 6 on the 20way black connector on the back of the warning lights
19th Feb 2018 4:57pm |
Thank you.
š» 2010 Range Rover MkIII Autobiography Super Charged (Idris) 2003 Range Rover Mk III (Desmond FitzWilliam) 2000 Defender 110 CSW TD5 (CTX) 1992 Range Rover Classic (Lizzy) 1972 Series III 300 Tdi (Stanwood) 1967 MGB GT Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken (1880 - 1956) |
19th Feb 2018 5:01pm |
