![]() | Home > In Car Electronics > Troubleshooting Alpine Hands free issue |
I had the same problem and the mic had blown. Replacement was about £20 and half an hour to fit
![]() My build thread http://www.defender2.net/forum/topic17615.html |
nosnibod Member Since: 15 Aug 2007 Location: West Midlands Posts: 370 ![]() ![]() ![]() |
It's also extremely easy for the mic to come out of its socket on the back of the head unit. There are a lot of cables and not a lot of room behind there... Dave
Green Goddess - 1998 Defender 110 300tdi |
Helstoon Member Since: 08 Mar 2012 Location: West Cornwall Posts: 32 ![]() ![]() ![]() |
I had a similar problem, excuse the language, but I had it in the wrong hole, there are several that will take the jack plug!
Is the mic actually any good even when fully functioning? I've never had much luck with using it, sound quality at the other end is always stated as being poor - I've put it down to a combination of cheap part and noisey vehicle.
Is there an easy upgrade part that maybe does a better job of cancelling out the general noise in the vehicle? |
Wheel Member Since: 28 May 2014 Location: Essex Posts: 233 ![]() ![]() |
I had this on my brand new 64 plate 90 discovered when driving home from collecting it from the dealership.
It turns out it was/is a common fault ;- the mic plug comes out of the back of the head unit either in assembly during manufacture or in use !!!!! I'd suggest popping the head unit out + checking here first Good luck |
