Home > Technical > anyone know there way around a nanocom file |
razz Member Since: 02 Oct 2015 Location: norfolk Posts: 403 |
as you can see 4 n 5 are soooo flat ?
Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge Click image to enlarge |
27th Jan 2018 2:05pm |
27th Jan 2018 2:10pm |
last one , i sat on our local bypass with my foot planted, not all the time , but when i look , i can not see the this on the revs , or is this a part of how the ecu works ?
27th Jan 2018 2:21pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2227 |
4 and 5 arnt flat, if you look at the scales you will see that they are scaled differently - due to the huge spike in the traces.
Steve 02' 110 TD5 Double Cab Rebuild Thread |
27th Jan 2018 7:58pm |
TO build upon RalleySteves answer, it is a good idea to export the data as a .csv, import it in to excel and adjust the scales to the same values.
27th Jan 2018 8:05pm |
cheers dudes , is my first attempt , don`t have excel on this pc , will give it a go at work , thank you
27th Jan 2018 8:22pm |
