![]() | Home > eBay & Bargain Spots > Bargain x5 boost alloys with mtr tures |
jaydt Member Since: 31 Aug 2013 Location: west midlands Posts: 36 ![]() ![]() |
Set of 5 boost alloys with Goodyear wrangler mtr 235/85r16
EBay item number eBay Item No. 222709041527 A bargain for someone |
Kit Member Since: 12 Feb 2016 Location: Shropshire Posts: 1110 ![]() ![]() ![]() |
They shouldn't crack in 6 years unless they're cheap (which Goodyear MT are not), 10 years is the industry standard for replacing them if I remember correctly? 1993 200 Tdi 90 CSW
1956 Series 1 Hard-top 1958 Series 1 Soft-top |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20629 ![]() ![]() |
Kit - You are right, I don't know 10 years was the standard as a rule then?
I know they need to be kept an eye on after around 6 years though but as you say, mainly applies to cheaper brands. That and being stood and not in use for long periods of time. TheThunder Rollsπ¬π§πΊπΈ β½οΈπ’οΈβοΈπ§°πͺ |
http://www.michelin.co.uk/tyres/learn-shar...e-my-tyres
Michelin say: How old is too old? The five year test After five years or more in service, your tyres should be thoroughly inspected at least once per year. If the need arises, follow the recommendations of the vehicle manufacturer regarding replacing the original equipment tyres. As a precaution, if the tyres have not been replaced 10 years from their date of manufacture (see how to read a tyre sidewall), Michelin recommends replacing them with new tyres. Even if they appear to be in usable condition and have not worn down to the tread wear indicator. 10 years recommended to replace even if they look fine ![]() 1956 Series 1 Hard-top 1958 Series 1 Soft-top |
👍🏻👍🏻 TheThunder Rollsπ¬π§πΊπΈ
β½οΈπ’οΈβοΈπ§°πͺ |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
I've got a set of 5 Avons on one of my 80s
All Manufactured between 1962/ 1959..... ![]() Luckily they don't go over 40mph ![]() Wanted, Forward Control Anything considered. |
Lightningtweeds Member Since: 16 May 2017 Location: Fintry Posts: 461 ![]() ![]() ![]() |
My old pattern BFG muds are coming up 10yo and you could put them back on the rack. 35,000m.
