Home > Technical > rear mud flaps removal
Djcla
Hi
trying to restore my cross member and as part of that get the old mud flaps off. on the one side the bolts snapped off and i managed to knock them through to clear the holes . Question is how to you go about putting new bolts in or do i need some rivnuts in there and if so what size and any ideas what tool i need?
Post #658585 20th Oct 2017 2:53pm
Balvaig
I used aluminium rivnuts when replacing mine. Aluminium is soft enough to enable you to insert them without a rivnuts tool. I just used a bolt, two nuts and a washer to insert them. I think they were M8 size, but you will find the sizes specified when you buy them. You have done the hard bit in getting the old fixings out!
Post #658589 20th Oct 2017 3:32pm
Yes, you'll need rivnuts. The size will be determined by the bolt size but without going and crawling under mine I'd guess they're M6.
Rivnuts can be set using a cunning combination of nuts on a suitable bolt - I thin there's a sticky about this somewhere. Alternatively, use a proper rivnut tool, which looks a lot like a rivet gun. They're available for not huge cost on the likes of eBay and Amazon. Darren
Post #658595 20th Oct 2017 3:56pm
X4SKP
Hello Djcla
Yes Rivnuts are the way to go... Thumbs Up
Standard Size M6, I replaced all mine when preparing to Dinitrol and wanted the old flaps off.
I managed to get SS Rivnuts to work with a DIY Tool, protected the treads (shown below) prior to applying the Dinitrol and then used SS Bolts (nicely greased) hoping to avoid the seizure of these later on...
These are obviously all directly in the firing line off the rear (and front) wheels... Exclamation
Good Luck... SKIP
Post #658600 20th Oct 2017 4:17pm
Djcla
something like this ?
http://www.ebay.co.uk/itm/10-5inch-Heavy-D...Swls5Y6Q4~
No idea how it works but guess ill figure that out
Ive got the task of removing the exhaust side now which is proving tricky any tips? Some times i think the engineers who designed a Defender were having a right laugh at my expense.
Post #658603 20th Oct 2017 4:34pm
X4SKP
Hi again Djcla
Exhaust side is more tricky...from memory, I unhooked the Exhaust and managed to maneuver it far enough out of the way to get in there... first to deliberately shear off 2 out of the 3 bolts (just a rubbish arrangement...) when I knew they were corroded too much, also very difficult to get any PlusGas or similar into where it would be needed to try a loosen the threads. I did heat one bolt initially also, but didn't get anywhere.
I Drilled out what was left, (at this point I had already decided to do the lot with Rivnuts).
I blew out the 'cavity' with an air line (glasses on) to try and get all the rubbish out (successfully i'd say) prior to protecting the inside of the Cross Member.
Good Luck... SKIP
Post #658643 20th Oct 2017 7:39pm
greenlandrover
United Kingdom 2007 Defender 90 Puma 2.4 XS CSW Tonga Green
Djcla
I've got a rivnut tool.
If your heading north and passing Stourbridge anytime, you're welcome to pop in and fit your rivnuts with it.
Jason
Post #658720 21st Oct 2017 9:32am
Djcla
Thanks for that very kind, but tbh I'll probably just get one on eBay as I'll probably use it again
Post #658868 22nd Oct 2017 7:31am
greenlandrover
That was my logic too! Laughing
I bought the Sealey AK3984 off Amazon for £30.
Will PM you the link as I don’t think we’re allowed to link to commercial websites on here.
Replaced the cubby box rivnuts with it so far and it worked well. Have to do mudflaps at some stage too.
There are some threads on here regarding what type of rivnuts to use where. Basically like for like metal but there are some other good tips regarding corrosion prevention. Worth having a search around.
Jason
Post #658874 22nd Oct 2017 8:00am
Djcla
Cheers , i need to do my rear step as well which I guess are m8
Post #658902 22nd Oct 2017 11:30am
Djcla
Finally got my rear step and mud flap off, have to say some of the holes have seen better days. Now are all rivnuts roughly the same outside diameter size ? Does the hole have to be exact tight fit ?
Post #658957 22nd Oct 2017 4:10pm
