Home > Maintenance & Modifications > Equipe Roof Console |
lrmaniac Member Since: 04 Feb 2010 Location: Lisboa Posts: 762 |
I have recently bought a roof console ... the outback one ... it should be the same ...
for the lamp you can use the existing wiring...for the CB I've brought the wiring that came with the radio over the roof lining, down through the pillar next to the driver's seat and it's there, waiting for me to have a bright idea to route the wiring in to the battery ... the conection to the battery itself will be done by a professional ... I just do the dirty work! when the work is finished I'll post pics ... won't be able to finish it this weekend ... Regards Joao '10 Land Rover Defender 110 CC '08 BMW F800GS '64 SIIA Forward Control '69 SIIA 109 ZA CKD _____________________________________________ You have the right to remain silent. Anything you say will be misquoted, then used against you. |
21st Mar 2011 11:31pm |
Theater Member Since: 27 Sep 2010 Location: Pisa Italy Posts: 514 |
I recently installed a console Corsetti
http://davidecorsetti.files.wordpress.com/...-radio.jpg Equipe is like that, but it costs less The work is not easy !!!!! You must remove the front cover of the roof In the center of the roof there is a metal reinforcement ;you must remove it(It is welded to the roof) Cut the cover of the roof is great as the console For the lamp you can use the existing wiring, for the CB I've brought the wiring that came over the roof lining, down through the pillar next to the right seat . The CB antenna goes under the roof lining, from the console to the rear door . I did not install the radio Sorry, I haven't photos |
22nd Mar 2011 12:52am |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2945 |
I have one of the lrs consoles made by equipe although not fitted yet interior roof ribs do not have to be removed accordingig to equipe instructions ????? cheers chris
22nd Mar 2011 8:48am |
I have a Defender 90....
....Also in the instructions of the Corsetti's Consolle is not written to remove the central roof reinforcement... Remove the lining of the roof and try to mount the console ....I didn't understand how to do it , then I called Corsetti and they told me that I should remove the central roof reinforcement Try to call Equipe 4x4 (+39 02 33514438 ) or write an email to info ( info@equipe4x4.com ) |
22nd Mar 2011 5:53pm |
