Home > Td5 > kangarooing TD5
martindavis
United Kingdom 1999 Defender 90 Td5 HT Caledonian Blue
kangarooing TD5
1999 TD5 defender 90 kangaroos like a pig in every gear unless you drive it like you stole it its not remapped or anything like that and it doesn't matter if it is hot or cold its driving me mad any help would be appreciated thank you in advance
Post #625248 18th May 2017 9:00pm
Enid_Puceflange
Scotland 2002 Defender 110 Td5 DCPU Baltic Blue
Hi Martin
I'm interested to see what the consensus is here.....
I have just bought my first Td5 and experience the same , though only sometimes when pulling away in first
then from first to second gear.
I have been told that it could very well be the dual mass flywheel
And these used to shatter and were replaced under warranty when the
Vehicles were not far from old.
It could be this or a sloppy clutch
So , I look forward to hearing what is said here Thumbs Up
G My confidence has been writing cheques that my abilities can't cash for years.
Post #625256 18th May 2017 9:24pm
bankz5152
Could be the MAF.
Check for oil in the redplug and clean the MAP
Post #625260 18th May 2017 9:33pm
grafty99
Throttle pedal on the way out? Only a twin track as it's 1999. Worth getting it plugged into a nanocom and reading live data perhaps? 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #625262 18th May 2017 9:35pm
Enid_Puceflange
Grafts ,
Mine is a 2002 , same idea ??
Plug into the Nanocom?
Sorry to piggyback the op's thread Embarassed
Post #625272 18th May 2017 9:50pm
grafty99
I think 2002 (mine included) onwards have the NNN type ECU and therefore a three track throttle pedal. But this only makes them less prone to failure and not immune to it. I think nanocom gives you throttle pedal data live Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #625276 18th May 2017 9:55pm
Enid_Puceflange
Thanks Grafty
Time to buy beer and pick the brains of the techs at work Thumbs Up My confidence has been writing cheques that my abilities can't cash for years.
Post #625278 18th May 2017 9:58pm
grafty99
1990 Vogue SE
Post #625279 18th May 2017 10:04pm
martindavis
Hi i fitted a solid fly wheel as the duel mass had failed I wouldn't think its the clutch as it its still the same now as before I have put a multi meter on the m a f sensor and is reading as it should its on an m s b ecu I will have to track down a throttle peddle and give it a try as I don't have a computer to plug in Very Happy thank you for your reply's I will up date if I find anything
Post #625280 18th May 2017 10:15pm
MadTom
Czech Republic 1999 Defender 130 Td5 HCPU Baltic Blue
Try to just unplug the MAF, and clean the MAP and check air filter and air pipes for damage/blockage. This is fast and simple.
Than try to find someone with diagnostics (nanocom). "Drobek" = The Small One - Discovery 2, "BlufĂ­nek" = The Blue Thing - Defender 130, and for me at least Ford Mondeo Smile
Post #625298 19th May 2017 5:51am
huffhuff
United Kingdom 2001 Defender 90 Td5 HT Java Black
Mine did the aussie thing every now and then. But then it stopped for ages and ages. Then one day I was checking my fluid levels and noticed that I never plugged the lunch switch back in. So, I did...then started noticing it again.
So now it is unplugged. TD5 Defender 90
Discovery 3 HSE
Post #625307 19th May 2017 7:50am
You gotta love predictive text/spell checkers! Rolling with laughter
Post #625311 19th May 2017 8:08am
huffhuff
Ha. Damn autocorrect... Wink TD5 Defender 90
Discovery 3 HSE
Post #625313 19th May 2017 8:28am
gazman
United Kingdom 2003 Defender 90 Td5 HT Alpine White
so what switch was it huff? 2014 - current ..... 2003 defender td5 90 (my car)
2009 - current .... 2005 zx10r
Post #626190 22nd May 2017 11:55pm
martindavis
Hi I have Tryed unplugging the clutch switch on the master cylinder and still the same Banging Head
Post #626228 23rd May 2017 8:00am
