Home > Maintenance & Modifications > Removing axles - advice please
Lancerdoc999
I'm looking to treat my chassis (alongside lots of other things) I have jet washed 3 x now and removed the best part of 2-3 buckets of mud! There are still some areas that need attention. Looking underneath it seems there was some sort of protective covering but not sure what. Will be removing fuel tank and rear tub floor as part of a second row seat upgrade.
To my query. If I want to remove the axles (perhaps one at a time) whats the best way to hold the truck up. Won't obviously be able to use axle stands and I don't have a lift. Can I use thick wooden blocks under the chassis rails or under the rear crossmember. I have some sleepers and various concrete lintels kicking around. Removing them and all the connecting parts will allow me better access and can change bolts and bushes as go.
Thanks
Post #620691 1st May 2017 6:58am
ChrisWoods
United Kingdom 2009 Defender 110 Puma 2.4 USW Aintree Green
Sleepers under the chassis rails is probably best bet. Just make sure its stable before you go under. I'm in the process of making some bespoke pallet forks that fit the chassis so I can dinitrol my truck. 2009 2.4TDCi XS Utility Wagon.
Post #620693 1st May 2017 7:06am
Paulv8
1989 Defender 90 V8 Petrol CSW Alpine White
I used timber joists rested on two axle stands under the chassis in front of the rear axle when I did my v8. V8 90...WIP
Post #620704 1st May 2017 8:21am
Litch
"Won't obviously be able to use axle stands"
Sorry to ask but why not? Confused ONE LIFE, GET IT!
Post #620881 1st May 2017 8:11pm
Lancerdoc999
assume because axles will have been removed and not sure how safe they are if then used under the box sections of the chassis. They are shaped to sit flush around an axle and not a square box section. Correct me if i'm wrong.
Post #620913 1st May 2017 9:46pm
Andrew*Debbie
never mind
Post #621012 2nd May 2017 12:13pm
Thon
^^^This is my preferred method too.
The timber allows the top of the stands to "bite" so they won't move, providing they're of a suitable thickness and hardness. Axle stands are obviously strong enough (presuming they are rated as such) even if they don't sit under an axle. You just need to make sure it's nice and level, in gear, diff lock engaged, handbrake on, all remaining wheels chocked, etc, etc, and it'll be fine. You shouldn't need to go up too high once the axle is out anyway, which will help matters.
As always, you have to use your own judgement when doing this kind of thing, but it looks like at least 2 of us have used this method and survived Very Happy
Post #621020 2nd May 2017 12:41pm
Clive
United Kingdom 2004 Defender 90 Td5 X-Tech LE Zambezi Silver
Just as a slight aside, I find a drain cleaning attachment for the jet washer is pretty effective for getting crud out from the inside of the chassis rails. The kind that has a small brass head with jets pointed backwards on the end of a long flexy tube. You can feed it in through some of the several larger holes in the chassis and it works it's way down under pressure.
Post #621038 2nd May 2017 2:41pm
jst
i use axle stands to support the chassis rails. it depends how wide the 'Y' is it needs to sit square. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #621166 2nd May 2017 9:04pm
