Home > V8 > 98 3.5 V8 110 pickup..cant start after 6 years |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
If it's been standing it may have some valves stuck?
Take the rocker covers off and turn it over watching the valves go up and down. I take it you have a good spark at the plugs? 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
3rd Apr 2017 4:03pm |
Kit Member Since: 12 Feb 2016 Location: Shropshire Posts: 1110 |
I would also try flushing all the old fuel out and just use brand new stuff.
Did you change the oil too? Have you checked the spark with the plugs out of the head? Have you tested the injectors or is it a carb? Is it firing at all or just just turning over? |
3rd Apr 2017 4:09pm |
Also if it's on carbs, worth checking float needles are not stuck?
They don't like standing for that long, worth giving them a good strip down and clean out. 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
3rd Apr 2017 4:20pm |
Mash Member Since: 09 Feb 2015 Location: Guernsey Posts: 1674 |
I just injected some fresh fuel into the carbs and crank it over, a small syringe is good for that. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
3rd Apr 2017 5:50pm |
R1200GS Member Since: 12 Jul 2015 Location: Hampshire Posts: 265 |
Are you 100% sure you have the leads on the cap correctly...............?
3rd Apr 2017 7:27pm |
Mystique Member Since: 03 Apr 2017 Location: southern Africa Posts: 3 |
thnx for the quick response...
yeah...old fuel flushed infact i took down the gas tank to make sure it all out i gat a fat spark at the plugs its not firing at all... im from cranking it now with gas through the carbs.....oh boy now the starter is just turning with a loud noise...could be the Bendix i think.... im now stuck could it be iv crancked it too much valves are bend. or its just the starter this time?????? |
4th Apr 2017 6:55am |
en cleaned up the carbs.. needles...well i doont remember
4th Apr 2017 6:57am |
