Home > Maintenance & Modifications > SyncroGear SlickShift - wowsers!
huffhuff
United Kingdom 2001 Defender 90 Td5 HT Java Black
Wow! Ordered on Monday at 2pm. It Tuesday at 10am. Fitted it in my lunch break - literally 25 minutes. However, I had one grub screw refusing to come out so left the new nylon cup out so I could drive home (but now armed with my impact driver, will swap it out this lunchtime).
What a bloody difference! Got to be one of the top mods for a TD5. No more sloppy monkey arm gear shifts. They are short and toight (like a tiger). It's like driving a modern day manual box. Quick, short and exact. Well worth the £95!
I highly recommend! TD5 Defender 90
Discovery 3 HSE
Post #611347 22nd Mar 2017 9:52am
steve_c3
United Kingdom 2002 Defender 110 Td5 SW Epsom Green
That's a glowing reference! I bought one at Billing last year and had it sitting on my shelves ever since! Maybe I should make it my next job after painting the rear crossmember, fixing the side steps, touching up the Dinitrol, fixing the leaks etc etc!
Seriously though...it's now my next job! Very Happy 2002 Defender 110 CSW TD5
Post #611451 22nd Mar 2017 7:04pm
huffhuff
Ha, it's been on my list for ages too. I finally decided to buy one after reading another few good reviews (and having a bad day at work - buying stuff for the defender always makes you feel betterer).
It is such a worthwhile modification/upgrade.
It will literally take you half hour, go get it out of the shed. You'll wish you did it when you got home from Billing a year ago! TD5 Defender 90
Discovery 3 HSE
Post #611569 23rd Mar 2017 9:49am
epictrail
United Kingdom 2004 Defender 110 Td5 HT Chawton White
Sounds like a good upgrade. But if your selector cup ( part of the Syncro kit ) is worn already then just changing that makes a large difference. Even the genuine Landrover part is not expensive.
FRC 5959 http://www.onlinegearboxparts.com/product/...-frc-5859/
Post #611575 23rd Mar 2017 10:19am
huffhuff
Indeed, correclty setting your bias springs also helps getting rid of some of the gear stick 'wobble' and could make gear selection a bit easier (my bias springs were all out so not only did I have a very wobbly gearstick, but to get in to 3rd I had to kind of push left a bit as going - adjusting the springs resolved).
However, I wanted a tighter, shorter throw into gears. Fed up of whacking my knuckles on the raptor dash or deafening myself by hitting the volume knob Smile
So, if you're not bothered about travel from one gear to the next, then replace the nylon cup and fiddle with your springs to lose some wiggle. If you want a complete overhaul which makes you feel like you're driving with a normal, tight and modern gearbox, fit this kit Smile
Pic for reference;
 TD5 Defender 90
Discovery 3 HSE
Post #611577 23rd Mar 2017 10:27am
PD1
Thanks Guys, After reading this...Ordered. Job for the weekend
Post #611592 23rd Mar 2017 12:19pm
huffhuff
Did you fit it PD1? TD5 Defender 90
Discovery 3 HSE
Post #612526 27th Mar 2017 12:12pm
PD1
No, delayed on a flight back from the US. So the weekend got screwed
Post #612544 27th Mar 2017 1:28pm
Kit
United Kingdom 1993 Defender 90 200 Tdi SW Scotia Grey
I'd be interested to hear how you fair as well, the gear change on my lt77 is quite sloppy
Post #612555 27th Mar 2017 2:06pm
steve_c3
Ok, after it taking up space on my shelf for too long I've finally fitted my slick shift...and i like it! Gear changes are tighter and it gave me the chance to take up the wobble in the stick by adjusting the bias springs. Thanks HuffHuff for the push Thumbs Up 2002 Defender 110 CSW TD5
Post #613596 31st Mar 2017 1:44pm
Kit
Worth the cash then?
Post #613620 31st Mar 2017 5:31pm
steve_c3
Like most things, it's a personal thing but if I was to get another Defender, I'd fit it again! 2002 Defender 110 CSW TD5
Post #613635 31st Mar 2017 6:22pm
JustFX
United Kingdom 2000 Defender 110 Td5 CSW Coniston Green
I have just removed mine as I put a new gearbox in last weekend and it caused 2nd and Reverse to be a bit of a pain to get out of. I suspect a new (tight) box (Fnarr Fnarr) doesn't need the aid from the slick. But once its got a bit more slop in it I suspect I will refit.
Post #613636 31st Mar 2017 6:23pm
DefenderSmith
I purchased one at a Land rover show and fitted it myself, which I found fairly straightforward. However I could not for the life of me adjust the bias plate lined up.. getting 3rd and 4th lined up would push out 1st and second and vice versa. Since then whilst having work done at two different reputable Land Rover specialists I have asked them to have a go at correcting and they have both been unable to get the changes lined up correctly. Not sure whether to keep trying or just take mine off.
Post #703512 27th Apr 2018 10:13am
Harry.O
United Kingdom 1989 Defender 90 300 Tdi ST Nato Green
JustFX - I noticed the same when I fitted the Slickshift to a recon R380 box, after 500 miles it had loosened a touch and was much better. During the first 2k miles I adjusted the bias springs 2 or 3 times and it's held position nicely since then.
Whilst the turret is off its well worth checking the grub screw holding the yoke on the selector shaft is tight, mine came loose a couple of months back and the whole thing had to come apart again 2005 Td5 110 Hardtop
1989 300Tdi 90 Soft top
1992 200Tdi 90 Truck cab with Land Cruiser axles
Post #703529 27th Apr 2018 11:27am
