Home > Maintenance & Modifications > EGR removal |
ralton Member Since: 04 Feb 2010 Location: Durban Posts: 153 |
I've tried to read all the threads on this, but would like a little summary if possible.
Specifically: - is there a technical reason (besides emissions) for keeping this valve? - can it be removed and blanked off successfuly? - is it the advised action (i'm out of warranty)? - Anyone in you can recommend in SA? Thanks www.ralton.co.za |
24th Feb 2011 11:22am |
http://www.defender2.net/forum/topic358.html?highlight=egr Read Dgardel's post in blue on this thread...interesting read... http://www.defender2.net/forum/topic2227-15.html If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
24th Feb 2011 5:04pm |
Cool, thanks - i'm still in two minds about blanking it...
Mine appears to work ok, maybe i'll just clean it now and again. www.ralton.co.za |
25th Feb 2011 5:16am |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5035 |
My disco has had it blanked off the moment it left warranty.
I think if i blank my 90 off...i wont bother with the egr plate - ill just get Pete's patch to stop it working. Far more elegant and if the valve is faulty you wont get any fault codes and it still can run its clean cycle etc etc Mike |
25th Feb 2011 7:50am |
It was my intention of cleaning it periodically with brake cleaner, but I never seem to have the time or the inclination! I have been running with a 10mm blank for what must be nearly a year now with no problems! I suppose the age old addage of " If it ain't broke, don't fix it" must apply to me! I also agree that preventative maintenance can be better than waiting for a problem to appear! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
25th Feb 2011 8:24am |
