Home > Tdi > 200tdi Fluid Changes
Needalandy
United Kingdom 1983 Defender 90 200 Tdi PU Bronze Green
I plan to service my 200tdi 90 for the first time and need some advice on which brand and spec of engine oil, gearbox / transfer box oil and diff oils to use please?
I only do around 2-3k miles pa if that makes any difference.
Post #603727 21st Feb 2017 8:40pm
Retroanaconda
Here you go, straight from the manual.
I use semi-synthetic 10W40 oil in mine, just standard cheap stuff from the motor factors. I buy it in drums as I'm doing the 6k service every 6-7 weeks but doing such a small mileage as yours I would change engine oil annually.
Edit: Uploaded wrong pic! Corrected now.
Post #603733 21st Feb 2017 8:54pm
Retroanaconda
Also, bear in mind the manual was written in 1993. As such don't worry too much about brands, just get the right type of oil and you'll be fine.
Post #603735 21st Feb 2017 9:01pm
Needalandy
Thanks for the info. I've read somewhere that recommended gearbox oil had moved on to Mtf 94 is that right ?
Post #603765 21st Feb 2017 10:00pm
Retroanaconda
Yes, though many (myself included) still run ATF. It's certainly easier to get hold of and some LT77 boxes seem to prefer it, while others run better on the MTF94.
Post #603768 21st Feb 2017 10:04pm
DrRob
I use a good decent oil from a local motor Factors in my 200 Bow down
Post #613085 29th Mar 2017 4:06pm
