![]() | Home > Technical > Indicator relay |
Did you check behind dash?
Jon110 Member Since: 26 Mar 2016 Location: Newcastle under lyme Posts: 83 ![]() ![]() ![]() |
I didn't
![]() I removed the panel by the gear stick . Thought it would be one of the 6 relays there The instructions or any of the other threads never mentioned that |
Found the answer
So much for the instruction sheet. |
Spill...for other members?!
As you said behind dash for my2002 onwards.
Will look tomorrow and see if the information I found is correct |
Brendlynch Member Since: 06 Nov 2016 Location: Grouville Posts: 182 ![]() ![]() ![]() |
Out of interest did you use the wipac ones and was the relay you swapped out the 4th one along from the right?
