Home > Maintenance & Modifications > Dual switching a Lazer Utility 80 |
Likeomg Member Since: 29 Jun 2012 Location: Lake District / Newcastle Posts: 2640 |
Is it possible using the genuine Loom for a lazer work light to wire it so i can have a switch on the dash and one somewhere accessible from the rear door?
I have purchased the utility 80 to mount on the rear of the rack for a work light / reversing light... so would be ideal if possible, have 4x LR spot switches too use, one for each of my 3 LED's and then the 4th i planned as a additional work light switch...? Kind regards. Everything is going to be ran / fused by a bluesea safetyhub 150 too... |
30th Jan 2017 6:53pm |
Would it be as simple as splicing two switches into the system?
31st Jan 2017 10:27am |
It's certainly possible to do what you've described, although 'splicing two switches in' doesn't really cover it.
In order for it to work in such a way that you could turn it on at the dash and then wander around to the back and turn it off, you'll need two ON-ON switches wired in series on the power feed to the lamp. This is much the same as light switches in a house at the top and bottom of the stairs. If you want something a bit more sophisticated such as automatic operation when selecting reverse or using non-latching push buttons, then the circuit gets a bit more complicated. There are lots of variations of how it can be done depending on exactly how you want it to look and operate. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
31st Jan 2017 10:45am |
Hmm, my plan was just to have it activated at one switch at a time,
I.e. if i'm reversing just hit the switch on the dash, if i've come back from a ride open the rear door and hit the switch.. i don't think id need it like you describe upstairs and downstairs lighting but if this isn't too complicated would also be nice... i had planned to use LR switches to control the work light... |
31st Jan 2017 11:09am |
Ah, ok. That'll work; it's just not very elegant
As I say, there are lots of different ways of doing this, depending on exactly what you want. For example, here's a circuit that allows for a switch on the dash but automatic operation when selecting reverse: Click image to enlarge The 'dash switch' could be mounted in the rear instead, which would achieve what you want. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
31st Jan 2017 11:38am |
