Home > Maintenance & Modifications > Dual switching a Lazer Utility 80
Likeomg
Is it possible using the genuine Loom for a lazer work light to wire it so i can have a switch on the dash and one somewhere accessible from the rear door?
I have purchased the utility 80 to mount on the rear of the rack for a work light / reversing light... so would be ideal if possible, have 4x LR spot switches too use, one for each of my 3 LED's and then the 4th i planned as a additional work light switch...?
Kind regards.
Everything is going to be ran / fused by a bluesea safetyhub 150 too...
Post #597714 30th Jan 2017 6:53pm
Likeomg
Would it be as simple as splicing two switches into the system?
Post #597982 31st Jan 2017 10:27am
It's certainly possible to do what you've described, although 'splicing two switches in' doesn't really cover it.
In order for it to work in such a way that you could turn it on at the dash and then wander around to the back and turn it off, you'll need two ON-ON switches wired in series on the power feed to the lamp. This is much the same as light switches in a house at the top and bottom of the stairs.
If you want something a bit more sophisticated such as automatic operation when selecting reverse or using non-latching push buttons, then the circuit gets a bit more complicated. There are lots of variations of how it can be done depending on exactly how you want it to look and operate. Darren
Post #597988 31st Jan 2017 10:45am
Likeomg
Hmm, my plan was just to have it activated at one switch at a time,
I.e. if i'm reversing just hit the switch on the dash, if i've come back from a ride open the rear door and hit the switch.. i don't think id need it like you describe upstairs and downstairs lighting but if this isn't too complicated would also be nice... i had planned to use LR switches to control the work light...
Post #597994 31st Jan 2017 11:09am
Ah, ok. That'll work; it's just not very elegant Smile
As I say, there are lots of different ways of doing this, depending on exactly what you want. For example, here's a circuit that allows for a switch on the dash but automatic operation when selecting reverse:
The 'dash switch' could be mounted in the rear instead, which would achieve what you want. Darren
Post #597995 31st Jan 2017 11:38am
If you simply want two switches where either switch can switch the lamp on or off irrespective of the other switch, all you need are two single pole double throw switches, it is very simple. This would let you turn it on with one switch then off with the other.
This diagram (online, found with Google) shows the idea:-
The diagram is clearly aimed more at the domestic application, for a vehicle the "L" terminal would be the battery +ve and the "N" and its conncted wire, the vehicle earth. Ignore the bit about earth wires in the piture.
(If you wanted to use a relay, then the relay would go where the bulb is shown in the diagram.
Post #598010 31st Jan 2017 12:32pm
