- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Home > Tdi > TD5 seat box to fit TDI |
davew
Just the box under the driver's seat, you don't need to cut it as such, just remove the rivets and, IIRC, a couple of spot welds.
You will also need to create a filler panel as the resulting hole is larger than the cover plate. http://www.yorkshireoffroadclub.net/
17th Jan 2017 1:39pm |
MetalMatt
cheers managed to remove the under storage box lots of drilling out rivits
23rd Jan 2017 4:52pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
