Home > Technical > Defender lights |
sako243 Member Since: 08 Jul 2014 Location: Wales Posts: 1218 |
The lower switch which turns on the headlights is notorious for arcing and failing. I think from memory the full beam flash will bypass the switch which is why that might work. I don't know about Pumas but on the older vehicles a few screws hold in the plastic trim around the steering column. Once you have that off you can extract the switch, it should be fairly obvious if it's been arcing as the contact dimples will be damaged. Easy to replace.
Back vs front lights sounds like a dodgy earth somewhere in the rear perhaps. Try the drivers side rear corner. Ed 82 Hotspur Sandringham 6x6 95 Defender 110 300Tdi |
22nd Nov 2016 11:06pm |
AndyK822 Member Since: 04 Jan 2016 Location: Northern Ireland Posts: 12 |
Thanks mate, was working in that area fitting a swing away wheel carrier bottom attachment so will take a look.
23rd Nov 2016 9:34am |
