Home > Td5 > Rubber brake pipes
Welkman
Rubber brake pipes
Hello,
Which parts of the 110 brake system are rubber? Is it just the pipes that connect to the metal pipes from the calipers? I am thinking it would be good to replace them as they are now 10 years old!
Also any tips for flushing the brake fluid out and replacing it with fresh?
Thanks
James
Post #579612 22nd Nov 2016 7:51am
agentmulder
Kuwait
Yeah, just there for the front, but also a section on the rear brakes just forward of the T joint on top of the axle.
Flushing the brake fluid - hrrrm, for a start, simply disconnect the caliper to pipe union and watch it go! As for the caliper itself, fastest would be to 'pop' the pistons and again let gravity have its way. May as well help it on its way by pumping your foot a few times too. This will leave you with a rather large bubble to purge though (a system wide bubble!).
Another tactic is to purge the lines one at a time with a buddy opening and closing the bleed valves as you pump the brakes. Once the fluid runs 'new' (more clear) for each line consider it done. Done carefully, and topping up the reservoir as you go, you'll maintain an air free system, however your calipers will still have the old fluid in them for the most part.
There are also flex clamps to play with, but since you're replacing the flex it's moot, just drain away as you're going to have no chance to stop it - tricks or no tricks - once you disconnect any union upstream of any flex.
Maybe someone will have a smarter approach, if so I'm keen to learn!
Finally, asking about how to flush the brake fluid after 10 years suggests to me that the various caliper rebuild threads might be an interesting read - you may have some seized pistons there... Solved the bowel problem, working on the consonants...
Post #579614 22nd Nov 2016 8:24am
Welkman
I am in the middle of replacing the calipers ! Thanks for the information, I have only had the truck for ten years.
Post #579710 22nd Nov 2016 6:27pm
