Home > Technical > Instrument Panel Tow Light Stays ON
quantumfoam
United Kingdom 1998 Defender 90 300 Tdi HT Baltic Blue
I have a Defender 90 1998 and it has the normal tow hook and 7 pin socket which the previous owner fitted. Since owning the dashboard trailer light has always come on once the ignition is switched on and never goes out other than when the indicators are used then it blinks in time with the indicator panel lights. I have removed the tow socket and it was full of mud and corroded wires. Even when these were separated and cleaned the panel light still stays on. Anyone have any ideas about what may be the problem other than an earth fault which I am busy trying to check.
Post #576016 7th Nov 2016 11:31am
Castillo
Finland
I have same problem in my defender td5. I replaced some days ago all old original 73mm lights with new wipac led lights and so this tow light stays on. Why? defender 110 td5 2006
Post #576049 7th Nov 2016 2:27pm
dorsetsmith
it driven by switch at the top, be place to start on the 300tdi
Post #576055 7th Nov 2016 3:25pm
quantumfoam
Thanks for the electrical schematic it is very helpful. Will let you know if and when I get a solution. In the meantime I have removed the tow ball and socket
Post #576067 7th Nov 2016 4:41pm
quantumfoam
I changed the instrument panel led for an original bulb and everything worked so will leave it like that with original relay for the moment and change out the relay for a one suitable for led's later. Well it also passed the MoT although I had to make sure the smoke out the exhaust was reduced. Did this via a diesel treatment and cleaning out the air intake. As I didn't have a lot of time prior to the MoT test I used a less conventional method than removal of the intake (see attached pics). Now its a proper clean including removal of the intercooler and also the vent system pipes. Thanks for all the help.
Post #577345 12th Nov 2016 5:56pm
