![]() | Home > Maintenance & Modifications > Nakatanenga rear 3rd stop light |
Riverboy Member Since: 16 May 2016 Location: French sector, Earth Posts: 1288 ![]() ![]() |
Ah OK
![]() Can you make a brighter rear top light especially for tinted windows? That would be good ![]() |
nakatanenga Member Since: 12 Nov 2010 Location: Neumarkt Posts: 546 ![]() ![]() |
Of course we can....MOQ is 1000pcs WANTED:
SII or SIII in max 1.5k |
![]() Click image to enlarge Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Thanks picture Daniele, but that does not look so terribly bright to me. Hope other pictures will correct that observation.
Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
It's very bright, I taken the photo with the sun in front of me.
Compare with the lower stop, they are the JWS and they are very very bright. I'll try to take better pics Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
Is your rear window clear or tinted? What colour lens did you buy?
Good to hear, looking forward to more pictures. Mine arrived from Germany to Belgium, it will be end of the month before someone will bring it back here so that I can install it then. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
My windows are the standard light green LR tinted glass, no film. The lens color is the crystal clear, look at the first post (page 1). Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
I also have VGS tinted glass. MOT rules here state they are legal as long as 50% of the light shows. They mean here if it has 6 filaments/bulbs/LEDs and three are out it will pass, 4 it will not, there is no mention of luminescence or light loss through tinting. There is no mention of E markings or anything else. Should the light be electrically disconnected it is not a fail as they are not obligatory. If electrically connected it must operate as above or it is a fail. As for the rest of the EU I cannot comment but we all are aware I think how strict the German TUV rules are? If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
High Level brake light, safety brake light, third brake light, use whatever description you like.
Now I have not got time or energy to trawl through EU regulation 48 however Hella have done a useful legal guide on vehicle lights here Page 17 on safety brake light
OK no specific mention of them being type approved/E marked in that Hella guide but IF obligatory under EU 48 then I would guess has to be E marked as Peter mentioned earlier. Also gives m. in and max light output. I do not know what date/amendment of the third brake light come into force. However if there is a factory fitted light I would assume it would have to work. MOT guidelines talks about additional stop light light. What is meant by additional? An aftermarket light fitted by the car owner or the third brake light factory fitted? As far as I am aware the Nakatanenga rear high level brake light is fully road legal as a replacement unit for the factory fitted 3rd brake light. Brendan |
nicks Member Since: 21 Aug 2008 Location: south coast Posts: 469 ![]() ![]() ![]() |
Just fitted mine with a small electronic modification-
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3802 ![]() ![]() |
^ I don't get that? looks like the brake light is flickering on and off almost faulty...? then comes on..
Is that the modification or am I missing something? If its meant to be like that I would not like to follow you at night on a twisty road... |
It's a mod. When you first brake it flashes to gain more attention to the vehicle(s) behind, then stays solid, even if you brake again within 10 secs.
With a BAS 170 AB remap you wouldn't be following for long. ![]() |
170.. is that all
![]() >>>>>> Move OVER If your happy then fair play. A night picture although I appreciate hard to take would be good. |
