Home > Maintenance & Modifications > Coolant flush
lambert.the.farmer
England 1998 Defender 90 300 Tdi PU Rutland Red
Coolant flush
Probably been asked before but what is a good(safe and effective) brand of rad flush to use on an all aluminium engine and rad?
Cheers in advance. Rhubarb and custard let fly with their secret weapon.
Post #567743 30th Sep 2016 6:10am
I thought plain water gravity fed through was quite okay. (Not under pressure) TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
β›½οΈπŸ›’οΈβš™οΈπŸ§°πŸ’ͺ
Post #567774 30th Sep 2016 8:51am
RED-DOT
If it is oil contamination whether it is in the coolant system or an intercooler or a oil cooler the big truck companies flush with liquid clothes detergent. They use a whole bottle twice then a good flush with water but for a Defender i would cut it back to half a bottle. 2008 RS4 gone, 123d M Sport, and a Puma 90 XS..
Post #567783 30th Sep 2016 9:50am
lambert.the.farmer
It's the Jimny actually but the principles are the same. There is no actual reason for wanting to do it beyond wanting to refresh the coolant in readiness for winter, there are no blockages or any obvious sediments in it and the rad is only a year old anyway, but it has been suffering from a very minor drip from the water pump which is now replaced but I only had enough coolant to mix at about 25 pc when I did the pump so I had thought that as I need to up the concentration I may as well give the insides a clean while I'm there? Rhubarb and custard let fly with their secret weapon.
Post #567793 30th Sep 2016 11:43am
Retroanaconda
My usual process when changing coolant:
1. Drain old coolant and dispose.
2. Disconnect top and bottom hoses.
3. Insert hosepipe into top hose and run until water emerging from bottom hose is clear.
4. Repeat in reverse - water into bottom hose.
5. Flush and back-flush radiator in the same way.
6. Re-assemble cooling system/pipes.
7. Ascertain capacity of system from handbook.
8. Add correct amount of coolant necessary to achieve desired mix strength etc.
9. Top up with fresh water.
10. Run engine up to temperature to mix, check for leaks.
Post #567796 30th Sep 2016 11:50am
I prefer ready mixed coolant, yes more expensive but we have hard water here.
Maybe just aged coolant but I noticed a slight drop in running temp too which is a good thing once replaced. TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #567798 30th Sep 2016 11:56am
lambert.the.farmer
Thanks all. I think I had intended to flush it something like that cheers retro. I'm lucky enough to have nice soft water so have not needed the pre mixed stuff. Rhubarb and custard let fly with their secret weapon.
Post #567801 30th Sep 2016 12:17pm
dorsetsmith
if you can use rain water from a water but no problems with ground contamination and free
Post #567804 30th Sep 2016 12:25pm
lambert.the.farmer
Our shed roofs are under trees and whilst the water off them is certainly free of charge that's about all it is free of, it definitely ain't got a place in my engine. Very Happy Rhubarb and custard let fly with their secret weapon.
Post #567809 30th Sep 2016 12:41pm
dorsetsmith
free from ground contamination i.e. nitrate, line stone, all-so PH neutral
engine manufacturers recommend using deionized water to mix with antifreeze, deionized water in large a mounts is price
i have used rain harvest water in engine small and large i.e. 2x 205 LTR of antifreeze and rain harvest water to mix 50/50 engine cooling system clean as a bell 8 year later Thumbs Up
Post #567833 30th Sep 2016 2:25pm
That'd be okay if you were prepared to fine filter it, personally I wouldn't both.
Each to his own. Very Happy TheThunder RollsπŸ‡¬πŸ‡§πŸ‡ΊπŸ‡Έ
Post #567835 30th Sep 2016 2:47pm
pannawonica
Australia
Just changed the coolant on Puma 2.4 110, drained refilled with rain water (Not on water supply) redrained and refilled deionised water and coolant. I'm on this week with the MG RV8 same process but with silicone replacement pipes. It has a Land Rover engine in too! Thumbs Up Very Happy works for me!
Post #568001 1st Oct 2016 10:12am
