Home > Td5 > Headlights
Collydog Blue
United Kingdom 1999 Defender 90 Td5 CSW Epsom Green
Headlights
I've no headlights or sidelight at the moment, and I can't figure out if I'm missing something. I've checked all of the fuses and replaced the headlight stick switch and checked as much wiring as I can see, but I've still got nothing. It'll flash on the indicator stork but nothing for the head and sides.
I feel like I'm missing something, and just hoping it'll be a bad earth, but if anyone has any pointers it'd be really appreciated. Crying or Very sad
Post #565168 19th Sep 2016 7:25pm
Dave T
United Kingdom 1994 Defender 90 300 Tdi SW Cairns Blue
Did you change the indicator stalk, is it not that one that normally wears? 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #565180 19th Sep 2016 7:36pm
Collydog Blue
Dave, thanks, but yeah, I changed that only six months ago, so it's still quite new, so hopefully it's not that, but I'll have a check of it tomorrow.
Post #565185 19th Sep 2016 7:41pm
VeeTee
Netherlands
Do you have a cheapish multimeter? It is a good investment, just a few . You can work along the route and measure voltage or discontinuity at various points along the route from start to end, e.g. battery - fuse - relay - switch - headlamp... Cheers, Vincent
1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold)
1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold)
1975 Series III 88 V6, Light Green (sadly sold)
1996 Defender 110 CSW 300 Tdi, Epsom Green (sold)
2000 Freelander 1 TD4 3-drs, Silver (sold)
2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold)
MySite
Post #565201 19th Sep 2016 8:04pm
Dave T
If I remember right (for a 300 Tdi), they are fused individually (left and right) so to loose them all must be something common, which I think is that switch or the wiring to it, or do you have dim/dip? 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #565203 19th Sep 2016 8:06pm
^^^^ +1 Much better and easier for fault finding rather than replacing bits possibly to no avail. $W33T $0U7H3RN $UG4R
Post #565204 19th Sep 2016 8:06pm
Collydog Blue
Thanks all, just spoke with the father in law, and he's got a multimeter that I can use, so I'll see where I get with it, hopefully it's something cheap and easy to fix, thanks again. Very Happy
Post #565214 19th Sep 2016 8:25pm
Collydog Blue
And Dave, no dim/dip just side and headlight
Post #565215 19th Sep 2016 8:27pm
4RF RDS
Canada 2000 Defender 110 Td5 XS CSW Epsom Green
Check ground wires and did you also check the relay? 2010 Range Rover MkIII Autobiography Super Charged (Idris)
2003 Range Rover Mk III (Desmond FitzWilliam)
2000 Defender 110 CSW TD5 (CTX)
1992 Range Rover Classic (Lizzy)
1972 Series III 300 Tdi (Stanwood)
1967 MGB GT
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken (1880 - 1956)
Post #565235 19th Sep 2016 8:50pm
dorsetsmith
Post #565289 20th Sep 2016 7:50am
Collydog Blue
Big thanks to every one for you're help, and thanks for the charts Dorset Smith, I've now tested all my fuses,switches and relay, with a multimeter and they are all in order, so it looks like a bad earth somewhere, but sadly run out of good light until tomorrow, when hopefully I'll find it one way or another. Thanks again Bow down
Post #565437 20th Sep 2016 7:27pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
Personally I would check feeds with a bulb (I use a 21w or a headlamp bulb depending on the circuit) to load test the wiring. As it checks the wires ability to carry a current rather than just voltage.
Kind Regards
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #565464 20th Sep 2016 8:54pm
Collydog Blue
Thanks Will, I'll give it a try Smile
Post #565472 20th Sep 2016 9:06pm
dorsetsmith
The earth header is on bulkhead behind coolant header tank
Post #565523 21st Sep 2016 8:50am
Piggle
2003 Defender 90 2.5 TD XS CSW Bonatti Grey
hi, when mine packed up transpired that it was a failed relay hidden behind the dash...checked this one?
Post #565784 22nd Sep 2016 1:18pm
