Home > Puma (Tdci) > Aftermarket suspension for Puma 2.2 |
SkyFallSilver Member Since: 06 Apr 2013 Location: Kuwait Posts: 464 |
I like the look of the modified suspension with the yellow shock absorbers, I am not looking to lift my truck or lower it what suspension setup would compliment the defender for offroad and on road comfort ? 2016 Defender 90 Adventure Edition
2nd Sep 2016 6:17pm |
GREENI Member Since: 22 Aug 2010 Location: staffs Posts: 10381 |
Old Man Emu suspension is highly regarded and what I have on the 110...also they're yellow!
2nd Sep 2016 7:14pm |
Are they applicable to OEM springs ? 2016 Defender 90 Adventure Edition
2nd Sep 2016 7:20pm |
You can change the dampers and leave the springs standard.
3rd Sep 2016 6:24am |
What bushes do you recommend changing, my car has 50,000km / approximately 30k miles. 2016 Defender 90 Adventure Edition |
3rd Sep 2016 10:32am |
West Yorkshire Lofty Member Since: 09 Mar 2014 Location: Dumfries and Galloway Posts: 116 |
Morning, SupaPro or Polybush, supply kits that replace the worn rubber bushes. They last longer and tighten the suspension up. I changed my OE rubber bushes when I had 165 miles on the clock!
Cheers WYL 2015 90 Keeper 2005 R300 Keeper 2019 XC40 Shopping Trolley 2008 110 XS Utility (Friday Build) Gone! |
5th Sep 2016 5:29am |
am I reading it correct, 165 miles and not 165,000 miles ?
If yes I am surprised that its very early for bushes. 2016 Defender 90 Adventure Edition |
5th Sep 2016 9:51pm |
anyone tried fox shocks with the standard OEM springs? 2016 Defender 90 Adventure Edition
JOE_130 Member Since: 26 Nov 2014 Location: Chelmsford Posts: 104 |
Can't fault mine, totally transforms the ride. I've been very pleased with them on and off road, and that's with the standard 130 springs (and helper rear springs) at the rear which are very stiff. |
6th Sep 2016 3:10pm |
Yes you read correctly 165 miles, I had the bushes done at the same time as other upgrades. It seemed sensible to have them swapped when the shocks, springs, brakes, galvanised turrets and bushes all at the same time. The rubber bushes could have lasted a couple of months or years.
6th Sep 2016 5:46pm |
I'll go for that then. 2016 Defender 90 Adventure Edition |
6th Sep 2016 7:49pm |
