![]() | Home > Tdi > Brake Light again |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3347 ![]() ![]() ![]() |
Hi Guys,
My brake warning light came on this morning on the way to work. I stopped where I could and had a nose around underneath and none of the lines are damp or showing any signs of leaks and it stops in a straight line very well. I suspect the Cap is at fault however it is due for MOT and Service next week where the brake fluid should all be changed. I don't want it to fail on a brake warning light just coming on for no reason so other than the cap what else could it be? Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter ![]() |
What condition are the two wires that go into the cap? Ray
Think Ii have solved it,
One of the spade connectors had disintegrated and the float looks a bit suspect. Will change connector and give the float a clean along with some new fluid so hopefully will solve it Thanks as always for the replies ![]() Self confessed mileage hunter ![]() |
