Home > Tdi > Am I missing something? |
Vesuvius Member Since: 06 Aug 2016 Location: Northumberland Posts: 17 |
First of all hello... already spotted some old friends from Kielder 4x4 and disco3 posting here...
Formalities out of the way... I'm hoping to answer a quick question if I may impose on everyone's weekend... Just got myself an old '94 300Tdi 130 that has been rebuilt just a few hundred miles ago... I've been underneath it for the first time trying to resolve a jumpy speedo. I noticed a suspicious looking bell housing - is it missing 4 bolts? If so anyone got a part number that might work for me? Click image to enlarge Thanks, J |
6th Aug 2016 4:21pm |
Try this one - not sure the last picture was immediately clear.
Click image to enlarge |
6th Aug 2016 4:25pm |
Mash Member Since: 09 Feb 2015 Location: Guernsey Posts: 1674 |
Yes you are, hope this helps:
Click image to enlarge Click image to enlarge 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html 90 V8 - Maggie http://www.defender2.net/forum/topic42564.html 110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html 52HG25 lightweight https://www.defender2.net/forum/topic72342.html D3 Hse - Fiona Capri 2l S - Anna Think I might have a problem............ |
6th Aug 2016 4:51pm |
Cheers Mash!
Are they LR part numbers? I'll have to get that sorted before it goes anywhere I guess! |
6th Aug 2016 5:38pm |
Click image to enlarge also missing gear box wading plug to green arrow LR part number |
6th Aug 2016 6:07pm |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1782 |
IIRC when a Disco engine is mated to a Defender transmission, there are some bolts in the wrong place / not drilled and tapped ?
6th Aug 2016 6:53pm |
Is that what I have here? A disco engine and a defender box?
I don't know the full history of the vehicle but I think it is all defender. |
6th Aug 2016 7:03pm |
do you have drilled / threaded holes into the engine where the bolts are missing??
6th Aug 2016 7:07pm |
I've not looked in such detail...
I'll get back under it later. It all looks factory as the casting opposite each hole is shaped to be tapped. Will have a look and report back! |
6th Aug 2016 7:51pm |
Here is the other side.
Each of those ribs in the casting is opposite a bolt hole. Click image to enlarge |
6th Aug 2016 7:58pm |
Wrong image!
Try this Click image to enlarge |
6th Aug 2016 8:08pm |
m10 x 35 bolt flange head
6th Aug 2016 8:37pm |
CheersDS - that is perfect.
What is missing from the other two holes that are aligned centre? The look like they should be plugged with something? |
6th Aug 2016 8:48pm |
link to part numbers 300tdi engine and other defender part numbers
http://www.allbrit.de/UNI.cfm?PAGE=749047&SPRACHE=EN |
7th Aug 2016 5:53am |
