Home > Puma (Tdci) > Vibration on overrun after fitting Alive Comfort springs |
languedoc Member Since: 13 May 2016 Location: Edinburgh Posts: 283 |
I found this on mine with winter tyres. The weight shifting to the front on deceleration meant my rear tyres had a vibration.
1st Aug 2016 3:08pm |
TheJollyBodger Member Since: 27 May 2015 Location: Ramsbottom Posts: 74 |
Thanks, but it's definitely coming from the gearbox - I can feel it through the gear stick and under my feet.
1st Aug 2016 3:09pm |
couplands Member Since: 31 Aug 2011 Location: Peak District & Cornwall Posts: 1826 |
Could it be related to the handbrake drum..?
Just a thought. cheers simon |
1st Aug 2016 3:16pm |
I lowered my rear springs when in CH, this caused a vibration in the front propshaft... put normal springs back on and it went away. the other solution is to fit a D/C front prop (or stay under 75mph )
1st Aug 2016 3:31pm |
Its hard not doing with a Bowler tune and a heavy right foot
1st Aug 2016 3:32pm |
davew Member Since: 02 Jan 2012 Location: North Yorkshire Posts: 888 |
Sounds like it could be a propshaft issue, perhaps the change in geometry has revealed a tight spot in a UJ or the phasing is no longer correct.
I have no idea what the comfort springs are but if the vehicle has been lowered or raised as a result of them then there's a very good chance propshaft vibration is the problem. For raised vehicles it's often an issue that can be fixed by adjusting the phase of the front prop or replacing it with a double cordon version. http://www.yorkshireoffroadclub.net/ |
1st Aug 2016 3:34pm |
Fantastic - that's exactly what I needed to hear, thank you very much.
Now, how to phase a front prop |
1st Aug 2016 3:56pm |
First thing you should do is take the front prop off and drive it like that (diff lock in) to make sure the vibration goes away - if it doesn't then at least you've ruled the front prop out ! It's always the front prop by the way, it's a result of the front suspension geometry.
You can take it to a propshaft specialist or try adjusting it yourself via trial and error - assuming it's correct in the first place, make sure you mark the original position before you start. The local "guru" that's made custom props for me seems to be able to look at the relative angles of both ends and tell you what the phase angle should be... not sure if he has a formula in his head or uses some form of black magic but it does seem to work ! You're trying to compensate for the differing angles of the diff pinion and the transfer box by deliberately putting the UJs out of phase so they cancel each other out. Standard front shafts are already out of phase to compensate and my guess would be that when lowering a vehicle you should rotate them so they are further from being in phase. Lowering the ride height will cause the nose of the diff to rotate downwards which I think will increase the difference in angles between the diff pinion and the transfer box output. If it's only noticeable at speed it probably doesn't need to be moved far. Alternatively you can look at changing the pinion angle with some castor correction bushes used the wrong way around (they're normally used to compensate for a 2 inch or more lift). Lowering the vehicle will have effected the castor angle although normally it's not noticeable with less than a 2 inch change, as you're going the "wrong way" from the optimum pinion angle perhaps it becomes more noticeable with less change. http://www.yorkshireoffroadclub.net/ |
1st Aug 2016 7:18pm |
Thank you for the detailed response.
I'll speak to a few guys I know to see if they can recommend someone. Will it be doing any damage in its present state? It only really happens after lifting off when driving over 70 mph. |
2nd Aug 2016 10:20am |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2526 |
Hi Bodger. I think this video may explain your problem. Make sure you have the volume on.
http://www.macsmotorcitygarage.com/2014/07...d-phasing/ I find it hard to believe that Alive have not encountered this problem before. Defender 90XS SW Mini Countryman Cooper S Morgan Plus 8 |
2nd Aug 2016 11:01am |
