Home > For Sale & Wanted > [For Sale] Specialized Mountain Bike
Andyred90
Decided to have a garage clear out and sell my mountain bike.
2013 specialized camber comp 29er.This bike has been barely ridden and may have done 100 miles! It is in good condition & the spec is completely as new. The frame is a Large and therefore suitable for riders up to 6’4. Originally this bike cost over £2K so looking for £850
Will take a few pictures when I can get to it in the garage!
Frame:
M5 hydroformed tubing, 29" geometry, tapered HT, PF30 BB, Command Post routing, 142mm dropouts, sealed cartridge bearing pivots, replaceable derailleur hanger, bolt-on cable guides, 110mm travel
Rear Shock:
Custom Monarch RL with AUTOSAG, air spring, LO and rebound adjust, 197×48mm
Fork:
RockShox Reba RL 29, Solo air spring, tapered alloy steerer, rebound adj., standard QR dropouts, 110mm travel
Front Derailleur:
SRAM X7, 10-speed, S3 direct mount for DMD, bottom pull
Rear Derailleur:
SRAM X9, 10-speed, mid cage
Number of Gears:
20
Shifters:
SRAM X7, 10-speed, Aluminium trigger, w/MatchMaker clamp
Chainset:
Custom SRAM S-1250, 10-speed XC Trail double w/ alloy guard, PF30 spindle, S: 170mm, Others: 175mm
Chainrings:
36/22, w/ alloy guard
Bottom Bracket:
SRAM PF30, OS press-in bearing, sealed cartridge
Cassette:
SRAM PG-1030, 10-speed, 11-36
Chain:
KMC X10, nickel plate, reusable Missing Link
Pedals:
Resin Test Ride Pedals with toe clips, CEN std
Front Brake:
Custom Avid Elixir 3R, hydraulic disc, semi-metallic pad, HS-1 rotor S/M:180mm, Others: 200mm
Rear Brake:
Custom Avid Elixir 3R, hydraulic disc, semi-metallic pad, HS-1 rotor S/M:160mm, Others: 180mm
Brake Levers:
Custom Avid Elixir 3R, tool-less reach adjust
Handlebars:
Specialized XC Mini-Riser, 7050 butted alloy, 720mm wide, 10mm rise, 10-degree backsweep, 6-degree upsweep, 31.8mm
Stem:
Specialized XC Trail, 6061 alloy, 4-bolt, 8-degree rise, 31.8mm clamp, 6-degree rise, S: 70mm, M: 90, L:100, XL:110mm
Headset:
1-1/8 and 1-1/2" threadless, Campy style upper with 1-1/2" lower, cartridge bearings
Grips:
Specialized Sip Grip, half-waffle aramid-infused, S/M: Regular, Others: XL thickness
Rims:
Roval 29, alloy disc, 26mm wide, 32h
Front Hub:
Specialized Hi Lo disc, OS28 end caps, sealed cartridge bearing, QR, 32h
Rear Hub:
New Specialized Hi Lo disc, 4x-sealed cartridge bearing, 12mm thru-axle, 32h
Spokes:
DT Industry, 2.0 stainless
Front Tyre:
Specialized Ground Control, 2Bliss Ready, 60TPI, aramid bead, 29×2.3″
Rear Tyre:
Specialized Ground Control, 2Bliss Ready, 60TPI, aramid bead, 29×2.1″
Tubes:
Ultralight Presta
Saddle:
BodyGeometry Henge Comp, hollow Cr-Mo rails, 143mm
Seatpost:
Specialized 2014 butted alloy, single bolt setback, 30.9mm, S/M: 350mm, Others: 400mm
Seat Binder:
Specialized 7050 hard anodized alloy collar w/ QR, 34.9mm, black
Post #531523 14th May 2016 5:16pm
Likeomg
try pink bike..
Post #531524 14th May 2016 5:19pm
epictrail
United Kingdom 2004 Defender 110 Td5 HT Chawton White
or Singletrack forum
Post #531525 14th May 2016 5:23pm
keith
Wow ! That's the biggest writeup on a bike ever Shocked
Nice tho .
Post #531555 14th May 2016 8:13pm
AJC
She's a beauty
Post #531608 15th May 2016 5:11am
JOW240725
Wow, great looking bike, wish I could afford it Big Cry James
Instagram @suffolk_rovers
Post #531617 15th May 2016 6:29am
Andyred90
Bump for the weekend
Post #533093 19th May 2016 10:37pm
Andyred90
Still for sale Very Happy
Post #542097 21st Jun 2016 3:50pm
Barneyboy
England 1986 Defender 90 2.5 n/a Diesel ST Nato Green
Hi you have a pm Thumbs Up Paul
Post #543392 25th Jun 2016 7:25pm
Andyred90
Now sold and collected 😀
Post #543500 26th Jun 2016 11:33am
