Home > Maintenance & Modifications > Windscreen blocks
lonewolf
United Kingdom 2010 Defender 90 Puma 2.4 CSW Zambezi Silver
Windscreen blocks
I would like to remove and repaint one of the windscreen blocks on my 90. It's held in place by 3 bolts. Is it ok to just remove them or will the two parts that are clamped spring apart if I loosen off and remove the bolts?
Someone must have experience of this Im sure?
Post #509817 1st Mar 2016 10:29pm
mk1collector
I took mine off to re seal them and nothing moved. Ray
My build thread
Post #509819 1st Mar 2016 10:31pm
Are they a specific torque Question
Post #509823 1st Mar 2016 10:39pm
mk1collector
I didn't torque mine up but as they are ali I would go nuts with tightening them up Ray
My build thread
Post #509824 1st Mar 2016 10:41pm
Screbble
Re: Windscreen blocks
You are safe to remove all 3 as long as you don't then go off-roaring! Thumbs Up
If you are going to that effort I'd suggest you do both and get new gaskets (with sealant) and take the opportunity to clean up the general area including the gutter etc.
You may wish to inspect the inside also behind the steel plate and clean and seal where appropriate.
As a self-confessed Anorak, I also cleaned up the internal steel plate and repainted that. Sadly, I also replaced the bolts with stainless steel, mindful of using Duralac when refitting.
Don't forget to use etch primer on the faux hinges Thumbs Up
Post #510074 2nd Mar 2016 6:37pm
K9F
I bit the bullet and replaced mine.
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #510083 2nd Mar 2016 7:16pm
Screbble
Mr. Green
I'm still very envious of those Mal, and the matching hinges. They are beautiful Thumbs Up
I think they're worth every penny, and very high quality.
One day......
Thumbs Up
Post #510088 2nd Mar 2016 7:37pm
Happyoldgit
Just be warned that original blocks are made of cheese so don't overtighten the bolts and keep surplus sealant out of the bolt hole as the blocks can fracture and split as the sealant has nowhere to go. Steve.
http://forums.lr4x4.com
Post #510129 2nd Mar 2016 8:49pm
I thought I had seen it written somewhere - but am struggling to find a source now.
Post #510273 3rd Mar 2016 10:55am
Oakseywick
United Kingdom 2000 Defender 90 Td5 XS CSW Java Black
I did the same as mal so need to ever worry about repainting them, also plan to get a set of the door hinges all round too when I can afford them!
Post #510286 3rd Mar 2016 11:26am
Land Rover Defender Windscreen Support Bracket Gasket kit
These seem a little different:
This listing is for a set of 4 gaskets that fit between the paintwork and the brackets used for supporting r for a Land Rover Defender.
Made in house on our laser cutting machine using high grade "Flexoid" UK manufactured gasket material
This is a far higher performance material that the standard cardboard type gasket material ( which has probably disintegrated on your car and why you are looking to buy new ones ! )
The gaskets can often become worn and can be a source of water leaks into the interior - especially where they are located at the end of the "gutter" channel that runs along under the windscreen.
These are NOT genuine Land Rover parts.
http://www.powerfuluk.com/vehicles/land-ro...t-4pc.html
Post #510310 3rd Mar 2016 12:13pm
K9F
I just made a set of my own gaskets out of butyl pond liner and a scalpel. Same for the stainless steel door and Safari Door hinges. If you go through life with your head in the sand....all people will see is an ar5e!!
Post #510479 3rd Mar 2016 6:51pm
lonewolf
Well there you go...thanks guys, I hadn't realised that there were gaskets, sealant , plates etc behind the blocks but I do now. It would have led to one of those Oh Sh!t moments if i'd just unbolted and pulled it off. I'll leave them a little longer for now until the paint bubbling really gets on my nerves and gets to the peeling off stage.....those shiny ones looked nice though. I'm doing a silver and black theme on the 90 and was going to paint the blocks black....we'll see but now I know what to look out for....cheers! Thumbs Up
Post #510499 3rd Mar 2016 8:21pm
Screbble
Re: Land Rover Defender Windscreen Support Bracket Gasket ki
I used those^
Not too bad for the money, but as stated they are easy enough to make yourself Thumbs Up
Post #510521 3rd Mar 2016 9:41pm
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
Clean it up, sure you'll find lots of corrosion in there... just did mine. Be sure to use LOTS of sealant. Run a bead around the outside diameter of all the holes, and then the outline of the gasket.
 it's a Landrover thing...
my renovation thread:
http://www.defender2.net/forum/topic40792.html
Post #510540 3rd Mar 2016 10:32pm
