Home > Technical > Shaking Defender |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
Things I would check:
- Are both the driveshafts tight on both end. - Is there play on the hand brake drum. (I had that recently. The driveshaft was tight but the nut that hold the flange had some play) Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
21st Nov 2015 3:05pm |
Happyoldgit Member Since: 14 Sep 2007 Location: Norfolk Posts: 3471 |
I once had a set of wheels and tyres that caused a wobble at certain speeds, no amount of balancing, changing wheel positions, rebalancing and beads would cure it. To all intents and purposes the various components in themselves checked out ok. Steve.
21st Nov 2015 3:10pm |
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 |
Could be a slightly warped disc?
But if it's intermittent maybe not, just a thought. Does the shaking get worse on heavy braking? 80" 80" 86" 88" 90" Wanted, Forward Control Anything considered. |
21st Nov 2015 3:14pm |
Penguin Member Since: 08 Dec 2014 Location: Tienen Posts: 247 |
21st Nov 2015 3:16pm |
It is less than 6 months old. Take it back to your dealer with the original wheels on it and get them to find origin of the problem and resolve.
Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
21st Nov 2015 3:18pm |
Mo Murphy Member Since: 01 Jun 2008 Location: Letchworth Garden City, Herts Posts: 2227 |
Sounds to me like swivel preload is incorrect.
21st Nov 2015 4:01pm |
So if it's not on the original set from the dealer I guess a question to ask is what wheel and tyre combination is giving the problem? Steve.
21st Nov 2015 9:54pm |
it is on the original set, only less frequent and less intense.
If it was the swivel preload, wouldn't I feel it more on the steering wheel? I'm pretty sure it's not the front wheels that are vibrating. Taking it to the garage is an option, but missing the def for some day's is not 28/02 - Loss of a good friend... In a time of chimpanzees, I was a penguin. |
22nd Nov 2015 8:01am |
Could this be the cause?
https://goo.gl/photos/e15LcvBRDxHTV1fQA Both sides were loose 28/02 - Loss of a good friend... In a time of chimpanzees, I was a penguin. |
28th Nov 2015 10:12am |
You mean the clamps on the steering rod, or tie rod? Sure!
How is the drive with them fixed firmly? Cheers, Vincent 1959 Polynorm 1/4 Ton Trailer, Olive Drab Green (sold) 1970 M416 Military Trailer (Camping Trailer Conversion), Epsom Green (sold) 1975 Series III 88 V6, Light Green (sadly sold) 1996 Defender 110 CSW 300 Tdi, Epsom Green (sold) 2000 Freelander 1 TD4 3-drs, Silver (sold) 2006 Freelander 1 TD4 5-drs Facelift Automatic, Tonga Green (sold) MySite |
28th Nov 2015 10:21am |
28th Nov 2015 10:24am |
After some visits to the dealer, who could not find anything wrong, except blaming it on bad calibrated wheels, I decided to replace the stock suspension with HD suspension.
Guess what: Problem solved. This is how the front stock spring looked like when still in place: Click image to enlarge As it is now: Click image to enlarge 28/02 - Loss of a good friend... In a time of chimpanzees, I was a penguin. |
22nd Feb 2016 7:02am |
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 809 |
Sounds like you had a lazy damper then or a worn bush that has either been replaced during the install or tightened up by the change in suspension geometry.
23rd Feb 2016 7:54am |
Remember you said you would have that lovely truck Dinitrolled?
Didn't happen I guess. Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
24th Feb 2016 3:24am |
