Home > Technical > Correct Location of Defender TD5 Alarm Sounder Unit |
pm sent
10th Feb 2016 8:19pm |
nitram17 Member Since: 08 Jun 2014 Location: newcastle Posts: 2261 |
Th BBUS on the newer model Pumas is located on the near side next to the fuel tank at the rear and is very difficult to find!I (the loom is inside the chassis!) I am willing to post this on here as I believe that the scroats that will pinch your truck will already know this new location and i find the secrecy on here a bit over secret squirrel.......if you cannot find it pm me and i will send you a map! |
10th Feb 2016 8:49pm |
landybear Member Since: 18 Oct 2015 Location: Tamworth & Worcester Posts: 134 |
Thanks for the reply folks. 2003 Defender TD5 Hardtop (current - work in progress)
2014 Discovery 4 HSE (Current) / 2009 Discovery 3 HSE 2009 (Previous) Disco 2 Landmark 2004, 2001, 2002 (Previous) Disco 1 300tdi 1996 & V8i 1995, 200tdi 1993 (previous) Defender 110 300tdi 1993 (Previous) Range Rover Vogue 4.6 - 2001 (Previous) Freelanders TD4 (2001 3 door & 2002 5 door) Previous 90 2.5 then converted to V8i (1990), 90 2.25 then converted to v8 (1986) plus others |
10th Feb 2016 10:00pm |
pjb Member Since: 08 Apr 2009 Location: Sunny Oxford Posts: 1244 |
But he has a TD5 2020 P300 HSE |
11th Feb 2016 7:13am |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2945 |
On a recent tour of factory the looms on Pumas have not been inside chassis
11th Feb 2016 7:55am |
Were you paying attention Ibex?
11th Feb 2016 6:00pm |
If I'm correct it appears the TD5 was spec'd with either the standard horn or the BBUS. Having checked it all out in daylight now, I have a cunning plan which plan which means removing and stripping / modifying the wing loom to relocate the BBUS. What I'm unsure about is if you can run with both the standard horn in place and the BBUS connected or does this cause a problem with the 10AS control? I'm sure it will work but prepared to be corrected!! 2003 Defender TD5 Hardtop (current - work in progress)
11th Feb 2016 6:59pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17380 |
Yes you can with no problem. To save the aggro of remanufacturing the wing harness you could buy one of the new FCX BBUS relocator harnesses.
11th Feb 2016 7:11pm |
Thanks for the tip. Will need to investigate the FCX loom! 2003 Defender TD5 Hardtop (current - work in progress)
11th Feb 2016 7:17pm |
gazman Member Since: 17 Aug 2015 Location: Liverpool Posts: 652 |
I run a std horn and the std td5 bbus sounder. Their is enough room and play to move the alarm from behind the headlight to back up by the heater and leave the horn connected. Don't waste your money on anything else.
Gaz 2014 - current ..... 2003 defender td5 90 (my car) 2009 - current .... 2005 zx10r |
11th Feb 2016 8:37pm |
Yes what's the problem |
12th Feb 2016 9:16am |
Finally got round to fitting the BBSU at an alternative position. It took a few hours to strip the loom apart and divert but well worth it and much cheaper than buying a new loom. As usual its one job off the list but uncovered some more jobs to do ... and so it goes on!!! 2003 Defender TD5 Hardtop (current - work in progress)
20th Feb 2016 4:02pm |
