Home > Puma (Tdci) > Radio reception |
red Defender Member Since: 11 Feb 2008 Location: Cornwall Posts: 76 |
yes, had radio replaced Whats broken now ?
25th Nov 2008 6:42pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5035 |
My radio has reasonably good reception with the aerial not extended Mike
25th Nov 2008 6:52pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8025 |
mines good and i live in a bad reception area. Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
25th Nov 2008 7:22pm |
Bosun Member Since: 21 Jul 2008 Location: Great Berry Posts: 141 |
Ditto. Might be a duff radio, but also check the ariel connection into the back. I had one that was not connected properly.
Bosun. |
26th Nov 2008 7:24am |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
Thanks for your replys chaps. 2.4 90 XS
26th Nov 2008 8:31am |
cobs Member Since: 12 Jun 2008 Location: North Yorkshire Posts: 336 |
check that AF is set
26th Nov 2008 7:16pm |
cobs,I'll check that cheers. 2.4 90 XS
30th Nov 2008 11:01am |
parktag Member Since: 30 Sep 2008 Location: Brittany Posts: 366 |
My radio reception is excellent without the keys in, but when i turn on the ignition the ECU interferes with the reception (same with engine running). The reception goes bad and picks up electronic beeping, especially when using the accelerator. I'll have it looked at when it's serviced. Bloody annoying but the CD is fine. 130 crew cab
98 V8 Disco |
6th Dec 2008 11:19pm |
Well it would be. Whats happening is the interference comes to the radio through the electrical system (earth and live) - not know where it is...what you do need is a surpressor (readily avaliable) what screens the + feed to the stereo; thus removing noise. Mike |
7th Dec 2008 10:13am |
I have a supressor but am unsure how to fit it. Nobody else seems to have a problem with this interferance so i'll leave it until it's first service, anyway i'm thinking of putting in a better system. I find it hard to press the right buttons without looking at the radio. On the single track roads i drive its dangerous.
Thank's for the suggestion. 130 crew cab 98 V8 Disco |
8th Dec 2008 11:35pm |
